Hello all!
I am design a new computer module based on imx28 heg (energy gateway) platform and actually I have the following questions:
1). For what purpose the connexions between SoC (imx28) and memory (DDR2) appear with some data pins exchanged like:
SoC DDR2
EMI_D07 DQ0
EMI_D04 DQ2
EMI_D02 DQ3
EMI_D00 DQ4
EMI_D03 DQ6
EMI_D06 DQ7
EMI_D10 DQ9
2). The layout has made with only 4 layers, it's great but checking the connexions between the SoC(iMX28) and memory (DDR2) I've found that some lines are routed in TOP and BOTTOM layer and in some cases some address and data lines has no equal vias distribution (some address and data lines signals has routed in only one layer and the rest has connected using 2 vias). Reading the document about how route memory signals in imx28 I've found that would be great if all the DDR2 signals has connected on one layer, preferably above a ground plane (without split planes).
My principal question is: I can draw a similar schematic and layout a PCB with the same characteristics that I've found?
Thanks anyone,
Christian Vieira
