We are trying to integrate imx219 camera module with iMX8QXP custom board. We have succeeded to stream image through MIPI CSI-2 from imx219 sensor based on following article.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8QXP-capture-raw-bayer-data-and-deba...
The ISI has been set to bypass the image format conversion (CSC), when the image sensor is configured as V4L2_PIX_FMT_SRGGB8.
But we are seeing that color values are not correct in output image. We'd like to know following.
1. Does i.MX8QXP ISI and MIPI-CSI2 support RAW8 image format?
2. Is there any way to capture the output of MIPI CSI-2 module (before giving to ISI)?
What is the output format from the camera?
What is the part number of your i.mx8qxp?
