imx219 Camera not working with IMX8QXP
Search instead for
donet
We are trying to integrate imx219 camera module with iMX8QXP custom board. We have succeeded to stream image through MIPI CSI-2 from imx219 sensor based on following article.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8QXP-capture-raw-bayer-data-and-deba...
The ISI has been set to bypass the image format conversion (CSC), when the image sensor is configured as V4L2_PIX_FMT_SRGGB8.
But we are seeing that color values are not correct in output image. We'd like to know following.
1. Does i.MX8QXP ISI and MIPI-CSI2 support RAW8 image format?
2. Is there any way to capture the output of MIPI CSI-2 module (before giving to ISI)?
Tags (2)
jimmychan
What is the output format from the camera?
What is the part number of your i.mx8qxp?
