imx-vpu-hantro-daemon fetch issues
amberworth
While doing a
bitbake imx-image-full --runall fetch
to pull all the sources, ran into an issue getting
imx-vpu-hantro-daemon-1.0.0.tar.gz
Error messages from bitbake:
ERROR: imx-vpu-hantro-daemon-1.0.0-r0 do_fetch: Fetcher failure for URL: 'https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.0.0.tar.gz'. Unable to fetch URL from any source.
When I try pulling manually, I get a zero byte file.
Any suggestions for where/how to get this for the build?
joanxie
it seems the network issue, you should try more times, I have downloaded this and uploaded here
jclsn
Same issue with 1.1.0
wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.0.tar.gz
--2022-02-16 15:31:49-- https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.0.tar.gz
Resolving www.nxp.com (www.nxp.com)... 23.75.229.22
Connecting to www.nxp.com (www.nxp.com)|23.75.229.22|:443... connected.
HTTP request sent, awaiting response... 304 Not Modified
2022-02-16 15:31:49 ERROR 304: Not Modified.
@joanxieCan you please provide a mirror for it here as well?
joanxie
eric_lee1
Hi joanxie,
Lately I try to build i.mx8mp yocto kirtstone bsp and met the same issue. The imx-vpu-hantro-daemon version in kirtstone is 1.15.
I have been tried several days and still cannot get the package fetched. The 1.14 and 1.13 are fine so I am sure that it is not my network problem.
eric@ftp:~$ wget -c https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.5.tar.gz
--2022-12-28 12:01:09-- https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.5.tar.gz
Resolving www.nxp.com (www.nxp.com)... 104.116.5.240
Connecting to www.nxp.com (www.nxp.com)|104.116.5.240|:443... connected.
2022-12-28 12:01:10 ERROR 304: Not Modified.
Would it be easier if you can attach the imx-vpu-hantro-daemon-1.1.5.tar.gz for me?
-Eric
joanxie
mailed to you already
michaelchien1972
wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-hantro-daemon-1.1.5.tar.gz
The link now is not working, can you e-mail me the file?
joanxie
what's your mail address? pls submit a ticket and add my name on the title, then I can assign it and mail to you
"https://www.nxp.com/support/support:SUPPORTHOME?tid=sbmenu"
jviguera
Hi @joanxie
I'm having same problems with version 1.1.5:
ERROR: imx-vpu-hantro-daemon-1.1.5-r0 do_fetch: Bitbake Fetcher Error: FetchError('Unable to fetch URL from any source.', 'https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.5.tar.gz')
ERROR: Logfile of failure stored in: .../cortexa53-crypto-mx8mm-dey-linux/imx-vpu-hantro-daemon/1.1.5-r0/temp/log.do_fetch.1853444
Could you email me the tarball as well?
Thanks.
Javier Viguera
Digi International Inc.
joanxie
I don't know your mail address, pls create a new ticket and tell me the number
"https://www.nxp.com/support/support:SUPPORTHOME"
laodzu
Hi @joanxie - I am now facing the same problems with version 1.1.5:
dzu@krikkit:~$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-hantro-daemon-1.1.5.tar.gz
--2023-02-21 11:56:12-- https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-vpu-hantro-daemon-1.1.5.tar.gz
Resolving www.nxp.com (www.nxp.com)... 184.24.7.128
Connecting to www.nxp.com (www.nxp.com)|184.24.7.128|:443... connected.
2023-02-21 11:56:12 ERROR 304: Not Modified.
dzu@krikkit:~$
No file is downloaded, so I cannot proceed with the build.  Can either the problem with the file server be fixed or can you send me a version of the file?
Thanks in advance
  Detlev
laodzu
The download started to work again, so I finally have a copy of the file.
Thanks!
jviguera
@joanxie nevermind, it seems to be available now in the normal URL:
$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.5.tar.gz
--2023-01-30 13:30:36--  https://www.nxp.com/lgfiles/NMG/MAD/YOCTO//imx-vpu-hantro-daemon-1.1.5.tar.gz
Resolving www.nxp.com (www.nxp.com)... 23.65.234.175
Connecting to www.nxp.com (www.nxp.com)|23.65.234.175|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 129709 (127K) [application/x-gzip]
Saving to: ‘imx-vpu-hantro-daemon-1.1.5.tar.gz’
imx-vpu-hantro-daemon-1.1.5.tar.gz                          100%
