imx-usb with windows
sandhya_05
I am trying to use the imx_usb binary with an i.MX6ULL device.
I built the imx-usb binary using the following steps in the Cygwin terminal:
git clone https://github.com/boundarydevices/imx_usb_loader.git
cd imx_usb_loader
git reset --hard c598fd14d67
make
After completing the above steps, the imx_usb binary is generated.
Next, I put the board into flashing mode and executed the imx_usb binary in the Cygwin terminal.
However, I encountered the following error message on the console:
failed to run ./imx_usb
Could you please let me know if there is anything else that needs to be done?
Thank you in Advance.
Sandhya
