imx-ele-apps/aes_usage test with 50MB file fails
405件の閲覧回数
HH_Mov
As a test of the HSM on the i.MX93 the aes_usage test was ran with a 50MB file being en/decrypted.
However running the decryption on target resulted in:
./ele_aes_usage decrypt CTR /tmp/dummy-file.enc /tmp/dummy-file 0x3FFFFFFF > /dev/null
[ 1179.264527] fsl-se-fw se-fw2: hsm1_ch0: Not enough space in shared memory
[ 1179.271346] fsl-se-fw se-fw2: hsm1_ch0: Not enough space in shared memory
cipher_with_ele_cipher failed ret:0xff
(Encrypting a file resulted in the same issue)
For info: The reserved space for ele is 1MB
hexdump -C /proc/device-tree/reserved-memory/ele-reserved\@a4120000/reg
00000000  00 00 00 00 a4 12 00 00  00 00 00 00 00 10 00 00  |................|
00000010
Is this a configuration issue, or should the decryption of a large file be handled differently ?
3 返答(返信)
366件の閲覧回数
HH_Mov
Additional info:
The aes_usage app allocates output buffer space based on the size of the input.
Using a file of 125MB and more than 650MB of free RAM, this should not be an issue.
345件の閲覧回数
Manuel_Salas
Hello @HH_Mov
I hope you are doing very well.
Kindly share your BSP version.
Are you using a pre-compiled image? or did you compile your own (if so, please share the steps you followed)?
Salas.
294件の閲覧回数
HH_Mov
Hello Salas,
It is a custom yocto ScarthGap build, based on the karo and imx layers.
Running "ELE firmware version 2.0.0-64d8ef47" and Linux 6.6.52
The aes_usage app is obtained from: https://github.com/nxp-imx-support/imx_sec_apps.git: Branch master
With a few adaptations to make it run (e.g. nvm_daemon is started via init scripts in our case), and build using the sdk generated by our yocto build.
Did a small test using a file containing a short text string ("Alle appels zijn oranje"), encrypted on host and imported the aes key from the key_import example on target (0x3FFFFFFF).
./ele_aes_usage decrypt CBC another-cipher.txt another-secret-message.txt 0x3FFFFFFF
The result was:
Alle appels zijn oranje;m^▒▒▒F▒▒▒}▒ϸ▒▒
Then tested using a 50MB binary (encrypted on host).
./ele_aes_usage decrypt CTR /tmp/binary.bin.enc /tmp/binary.bin 0x3FFFFFFF > /dev/null
Then tested encrypting the binary.bin on target (to rule out something wrong with the encryption on host)
./ele_aes_usage encrypt CTR /tmp/binary.bin /tmp/binary.bin.enc 0x3FFFFFFF
Hello, World! Oct 13 2025:06:28:33 b83e779
message preview:
hsqs
SAB Error: SAB C[ 1573.976753] fsl-se-fw se-fw2: hsm1_ch0: Not enough space in shared memory
MD [0x30] Resp [[ 1573.983856] fsl-se-fw se-fw2: hsm1_ch0: Not enough space in shared memory
0xf29] - The key store is already opened by a user (load operation).
Key store already created, trying to load it...
SAB Error: SAB CMD [0x62] Resp [0x29] - General Error.
hsm cipher failed, ret: 0xff
Hugo
%3CLINGO-SUB%20id%3D%22lingo-sub-2183889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E50MB%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9Fimx-ele-apps%2Faes_usage%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei.MX93%20%E4%B8%8A%E3%81%AE%20HSM%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%A8%E3%81%97%E3%81%A6%E3%80%8150%20MB%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%2F%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%A6%20aes_usage%20%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E4%B8%8A%E3%81%A7%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E7%B5%90%E6%9E%9C%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fele_aes_usage%20decrypt%20CTR%20%2Ftmp%2Fdummy-file.enc%20%2Ftmp%2Fdummy-file%200x3FFFFFFF%20%26gt%3B%20%2Fdev%2Fnull%0A%5B%201179.264527%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0A%5B%201179.271346%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0Acipher_with_ele_cipher%20failed%20ret%3A0xff%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E(%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%A6%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%83%85%E5%A0%B1%3A%20ele%20%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%AF%201MB%20%E3%81%A7%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Ehexdump%20-C%20%2Fproc%2Fdevice-tree%2Freserved-memory%2Fele-reserved%5C%40a4120000%2Freg%0A00000000%20%2000%2000%2000%2000%20a4%2012%2000%2000%20%2000%2000%2000%2000%2000%2010%2000%2000%20%20%7C................%7C%0A00000010%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%A4%A7%E3%81%8D%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%BE%A9%E5%8F%B7%E5%8C%96%E3%81%AF%E5%88%A5%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2188949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-ele-apps%2Faes_usage%20test%20with%2050MB%20file%20fails%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2188949%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%B5%E3%83%A9%E3%82%B9%E3%81%95%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81karo%20%E3%81%8A%E3%82%88%E3%81%B3%20imx%20%E3%83%AC%E3%82%A4%E3%83%A4%E3%83%BC%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%9F%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20yocto%20ScarthGap%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%80%8CELE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.0.0-64d8ef47%E3%80%8D%E3%81%8A%E3%82%88%E3%81%B3Linux%206.6.52%E3%82%92%E5%AE%9F%E8%A1%8C%3CBR%20%2F%3E%3CBR%20%2F%3Eaes_usage%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fimx_sec_apps.git%3A%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3A%20https%3A%2F%2Fgithub.com%2Fnxp-imx-support%2Fimx_sec_apps.git%3A%3C%2FA%3E%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E8%AA%BF%E6%95%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%82%8B%E3%81%A8%EF%BC%88%E4%BE%8B%EF%BC%9Anvm_daemon%20%E3%81%AF%E3%80%81%E3%81%93%E3%81%AECASE%E3%81%AF%20init%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E8%B5%B7%E5%8B%95%E3%81%95%E3%82%8C%E3%80%81Yocto%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%20SDKs%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%9F%AD%E3%81%84%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E6%96%87%E5%AD%97%E5%88%97%20(%22Alle%20appels%20zijn%20oranje%22)%20%E3%82%92%E5%90%AB%E3%82%80%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%B0%8F%E3%81%95%E3%81%AA%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20key_import%20%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%8B%E3%82%89%20AES%20%E3%82%AD%E3%83%BC%20(0x3FFFFFFF)%20%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fele_aes_usage%20decrypt%20CBC%20another-cipher.txt%20another-secret-message.txt%200x3FFFFFFF%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3EAlle%20appels%20zijn%20oranje%3Bm%5E%E2%96%92%E2%96%92%E2%96%92F%E2%96%92%E2%96%92%E2%96%92%7D%E2%96%92%CF%B8%E2%96%92%E2%96%92%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%8150MB%20%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20(%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%E3%81%A7%E6%9A%97%E5%8F%B7%E5%8C%96)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fele_aes_usage%20decrypt%20CTR%20%2Ftmp%2Fbinary.bin.enc%20%2Ftmp%2Fbinary.bin%200x3FFFFFFF%20%26gt%3B%20%2Fdev%2Fnull%0A%5B%201179.264527%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0A%5B%201179.271346%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0Acipher_with_ele_cipher%20failed%20ret%3A0xff%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E4%B8%8A%E3%81%A7binary.bin%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%E3%81%AE%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%8E%92%E9%99%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E.%2Fele_aes_usage%20encrypt%20CTR%20%2Ftmp%2Fbinary.bin%20%2Ftmp%2Fbinary.bin.enc%200x3FFFFFFF%0AHello%2C%20World!%20Oct%2013%202025%3A06%3A28%3A33%20b83e779%0Amessage%20preview%3A%0Ahsqs%0A%0ASAB%20Error%3A%20SAB%20C%5B%201573.976753%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0AMD%20%5B0x30%5D%20Resp%20%5B%5B%201573.983856%5D%20fsl-se-fw%20se-fw2%3A%20hsm1_ch0%3A%20Not%20enough%20space%20in%20shared%20memory%0A0xf29%5D%20-%20The%20key%20store%20is%20already%20opened%20by%20a%20user%20(load%20operation).%0A%0AKey%20store%20already%20created%2C%20trying%20to%20load%20it...%0A%0ASAB%20Error%3A%20SAB%20CMD%20%5B0x62%5D%20Resp%20%5B0x29%5D%20-%20General%20Error.%0A%0Ahsm%20cipher%20failed%2C%20ret%3A%200xff%0Acipher_with_ele_cipher%20failed%20ret%3A0xff%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%92%E3%83%A5%E3%83%BC%E3%82%B4%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-ele-apps%2Faes_usage%20test%20with%2050MB%20file%20fails%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186257%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252198%22%20target%3D%22_blank%22%3E%40HH_Mov%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%85%83%E6%B0%97%E3%81%A7%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBSP%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BA%8B%E5%89%8D%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%BE%E3%81%9F%E3%81%AF%E7%8B%AC%E8%87%AA%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%20(SO%E3%80%81%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B5%E3%83%A9%E3%82%B9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20imx-ele-apps%2Faes_usage%20test%20with%2050MB%20file%20fails%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%3A%3C%2FP%3E%3CP%3Eaes_usage%20%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AF%E3%80%81%E5%85%A5%E5%8A%9B%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E5%87%BA%E5%8A%9B%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%20%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E125MB%20%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%20650MB%20%E3%82%92%E8%B6%85%E3%81%88%E3%82%8B%E7%A9%BA%E3%81%8D%20RAM%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
