imx-drm framebuffer rotation
3,107 次查看
ottawa-imx6
Hello, I am using the imx-drm with a parallel rgb lcd under 3.18. I have it working a little, but there are a few little issues that I am still working on.
1. Does anyone know how to do a permanent 180 degree vertical flip of the framebuffer contents while using imx-drm? I would like this in the kernel upon initialization.
2. Strangely, I had to enable the framebuffer console in my configuration to get the display to work at all... I don't need the fbcon, but there must be something that it does to enable my drm setup to work.
3. While using imx-drm, what do we set our bootargs in u-boot to? Previously, I had reference to mxcfb0, but now that we are using imx-drm, there is no reference to this mxcfb0. This could be the root cause of the above, but I cannot find any documentation on it.
Brent
标签 (2)
标记 (1)
2,271 次查看
fabio_estevam
Brent,
Please ask these questions at dri-devel@lists.freedesktop.org mailing list with the imx drm maintainer on Cc: Philipp Zabel <p.zabel@pengutronix.de>.
2,271 次查看
ottawa-imx6
Will do, thank you.
Brent
2,271 次查看
ivannikolaenko
Hi, Brent.
Did you solve your problem?
We faced it too.
