imx-4.9.88-2.0.0_ga: repo init error(403 Forbidden)
csoapy
I'm tring imx-4.9.88-2.0.0_ga according i.MX_Yocto_Project_User's_Guide.pdf, but repo init failed. See below:
gusarambula
Hello 计龙 杨,
Even with that error the repo was successfully initialized so you should be able to run repo sync to fetch the metadata of the layers of the BSP. You may encounter also a couple of missing mirrors but the log will let you know if it was successful.
Let us know if you have any problems while doing this.
