im6dual -> tftp server setup for yocto setup?
1,582件の閲覧回数
gbiradar
I'm trying to setup tftp server for im6dual board,
i have followed Yocto NFS & TFTP boot .
As setup mentioned in the DOC is for vmware.
As for my system setup is:
I'm using LAPTOP(ubuntu 16.04) with ext usb wifi dongle for internet and ethernet for nfs server. If i try to assign eth0 as static address i'm unable to get internet from usb wifi dongle. Is it possible to setup usb wifi dongle for internet used by PC system and eth0 for tftp nfs server.
regards,
Ganesh
ラベル(3)
タグ(2)
1,235件の閲覧回数
weidong_sun
Hello Ganesh,
     Your question is not related to I.MX6 & Linux BSP product, I can only give you some advice. Actually you don't need to use USB WIFI dongle.
     PC Ethernet & i.MX6DL board can be connected to Router or switch , you can not only use tftp/nfs but also internet.
Weidong
