iMx8QM MEK along with W-LAN+Bluetooth Combo Module (CYW88373) along with Android13
Hassan_Zafirul
We are utilizing the iMx8QM MEK in conjunction with the W-LAN+Bluetooth Combo Module (CYW88373) and Android13 running on A53.
Bluetooth and Wi-Fi are not working. We were unable to pair with WiFi or Bluetooth.
Is a driver or kernel configuration missing? Please give a solution or reference links.
We'd like to test the HFP / A2DP and Internet Radio use cases.
Chavira
Hi @Hassan_Zafirul!
Thank you for contacting NXP Support!
Unfortunately, our Android Image doesn´t contain the drivers for that module.
You would have to implement it by your side if you need it.
You can see the wifi modules available for our Android Image in the next document.
https://www.nxp.com/docs/en/release-note/RN00110.pdf
Sorry for the mistake!
Best Regards!
Chavira
