iMX95 DRAM timing settings
ソリューションへジャンプ
2,314件の閲覧回数
simonng
Hi NXP team,
I want to change the DRAM timing configurations for the iMX95. I think the timing configurations are set by the following codes in the ds file.
freq0 timing 0x5e080100 32 0x020D2100 #TIMING_CFG_3
freq0 timing 0x5e080104 32 0x4866000C #TIMING_CFG_0
freq0 timing 0x5e080108 32 0xF2F08C45 #TIMING_CFG_1
freq0 timing 0x5e08010C 32 0x20488010 #TIMING_CFG_2
freq0 timing 0x5e080124 32 0x0C230308 #DDR_SDRAM_INTERVAL
freq0 timing 0x5e080160 32 0x00000101 #TIMING_CFG_4
freq0 timing 0x5e08016C 32 0x01300000 #TIMING_CFG_7
freq0 timing 0x5e080170 32 0x8B010509 #DDR_ZQ_CNTL
freq0 timing 0x5e080250 32 0x00110A11 #TIMING_CFG_8
freq0 timing 0x5e080254 32 0x00680040 #TIMING_CFG_9
freq0 timing 0x5e080258 32 0x03003E80 #TIMING_CFG_10
freq0 timing 0x5e08025C 32 0x40520200 #TIMING_CFG_11
freq0 timing 0x5e080300 32 0x08110808 #TIMING_CFG_12
freq0 timing 0x5e080304 32 0x00680E02 #TIMING_CFG_13
freq0 timing 0x5e080308 32 0x06040603 #TIMING_CFG_14
freq0 timing 0x5e08030C 32 0x0030001C #TIMING_CFG_15
freq0 timing 0x5e080310 32 0x20610000 #TIMING_CFG_16
freq0 timing 0x5e080314 32 0x0A0A0407 #TIMING_CFG_17
Where can I get the descriptions of the above registers?
Simon
2,294件の閲覧回数
pengyong_zhang
Hi @simonng
Please refer the  DDRC registers description of i.MX93 RM documentation file. i.mx93 and i.mx95 use the same DDRC IP.
B.R
3 返答(返信)
2,295件の閲覧回数
pengyong_zhang
Hi @simonng
B.R
2,305件の閲覧回数
pengyong_zhang
Hi @simonng
We strongly do not recommend you modify the DDR timing parameters by yourself. Because this may cause unpredictable risks.
What is your purpose about this?
B.R
2,304件の閲覧回数
simonng
Hi @pengyong_zhang ,
I need to do some correlation tests on the DRAM devices. So, I want to adjust the timing such as tRCD and tFAW. I want to have the descriptions of the registers. Then I can adjust the value accordingly.
Simon
%3CLINGO-SUB%20id%3D%22lingo-sub-2071790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%20DRAM%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071790%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81NXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%3C%2FP%3E%3CP%3EiMX95%20%E3%81%AE%20DRAM%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81ds%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3Efreq0%20timing%200x5e080100%2032%200x020D2100%20%23TIMING_CFG_3%3CBR%20%2F%3Efreq0%20timing%200x5e080104%2032%200x4866000C%20%23TIMING_CFG_0%3CBR%20%2F%3Efreq0%20timing%200x5e080108%2032%200xF2F08C45%20%23TIMING_CFG_1%3CBR%20%2F%3Efreq0%20timing%200x5e08010C%2032%200x20488010%20%23TIMING_CFG_2%3CBR%20%2F%3Efreq0%20timing%200x5e080124%2032%200x0C230308%20%23DDR_SDRAM_INTERVAL%3CBR%20%2F%3Efreq0%20timing%200x5e080160%2032%200x00000101%20%23TIMING_CFG_4%3CBR%20%2F%3Efreq0%20timing%200x5e08016C%2032%200x01300000%20%23TIMING_CFG_7%3CBR%20%2F%3Efreq0%20timing%200x5e080170%2032%200x8B010509%20%23DDR_ZQ_CNTL%3CBR%20%2F%3Efreq0%20timing%200x5e080250%2032%200x00110A11%20%23TIMING_CFG_8%3CBR%20%2F%3Efreq0%20timing%200x5e080254%2032%200x00680040%20%23TIMING_CFG_9%3CBR%20%2F%3Efreq0%20timing%200x5e080258%2032%200x03003E80%20%23TIMING_CFG_10%3CBR%20%2F%3Efreq0%20timing%200x5e08025C%2032%200x40520200%20%23TIMING_CFG_11%3CBR%20%2F%3Efreq0%20timing%200x5e080300%2032%200x08110808%20%23TIMING_CFG_12%3CBR%20%2F%3Efreq0%20timing%200x5e080304%2032%200x00680E02%20%23TIMING_CFG_13%3CBR%20%2F%3Efreq0%20timing%200x5e080308%2032%200x06040603%20%23TIMING_CFG_14%3CBR%20%2F%3Efreq0%20timing%200x5e08030C%2032%200x0030001C%20%23TIMING_CFG_15%3CBR%20%2F%3Efreq0%20timing%200x5e080310%2032%200x20610000%20%23TIMING_CFG_16%3CBR%20%2F%3Efreq0%20timing%200x5e080314%2032%200x0A0A0407%20%23TIMING_CFG_17%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%AF%E3%81%A9%E3%81%93%E3%81%A7%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3CBR%20%2F%3E%E3%82%B5%E3%82%A4%E3%83%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX95%20DRAM%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Ei.MX93%20RM%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AEDDRC%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AC%E6%98%8E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82i.mx93%20%E3%81%A8%20i.mx95%20%E3%81%AF%E5%90%8C%E3%81%98%20DDRC%20IP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX95%20DRAM%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F202673%22%20target%3D%22_blank%22%3E%40pengyong_zhang%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EDRAM%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E7%9B%B8%E9%96%A2%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81tRCD%E3%82%84tFAW%E3%81%AA%E3%81%A9%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%97%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%AA%AC%E6%98%8E%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%E5%80%A4%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ESimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2071861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AiMX95%20DRAM%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2071861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F105311%22%20target%3D%22_blank%22%3E%40simonng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EDDR%20%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%87%AA%E5%88%86%E3%81%A7%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E4%BA%88%E6%B8%AC%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%AA%E3%82%B9%E3%82%AF%E3%82%92%E5%BC%95%E3%81%8D%E8%B5%B7%E3%81%93%E3%81%99%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EB.R%3C%2FP%3E%3C%2FLINGO-BODY%3E
