iMX8mq evk have high loading on android 10 OS
1,996 次查看
kevincheng
We check out new android BSP Q10.0.0_1.0.0 and do some test. When test 3D program, there CPU loading up to 200% loading by top command. We test android 9 is not this issue, how to solve it?
My test platform is iMX8MQ evk board.
Kevin
5 回复数
1,498 次查看
emmarobinson320
If the device isn't unlock-able, verifying the OS uses a hard-wired key. img file LiteBlue Login.
1,498 次查看
radhikasomaiya
Senior Contributor II
Hi kevincheng ,
When we run this apk for android 10.0.0_1.0.0. it shows "This app was built for an older version of Android". So please find another apk for android 10.
Radhika Somaiya.
1,498 次查看
kevincheng
Hi Radhika,
We use the other app to test, and same result.
Test app : 3DMark
APP source : https://apkpure.com/tw/3dmark-the-gamer-s-benchmark/com.futuremark.dmandroid.application
Test Result : CPU hold on high percentage like below
Kevin
1,498 次查看
radhikasomaiya
Hi kevincheng ,
Which 3D program you are trying to test with Q10.0.0_1.0.0. Can you please provide the detailed information to reproduce this issue or steps which you have followed ?
Radhika Somaiya.
1,498 次查看
kevincheng
You can download below apk to test.
https://apkpure.com/tw/stabilitytest-root-optional/com.into.stability
Kevin
