Planning to use GPIO as a wake up source. Can we use SCU_GPIO0 to wake-up the i.Mx8 (both A35 and M4).
Could you please confirm whether we can use this gpio as wake up source?
Solved! Go to Solution.
Hi nxf65583
yes SCU_GPIO0 can be used to wake-up the i.MX8 (both A35 and M4).
Wake procedure is described in sect.5.1 Wake from Low Power sc_fw_api_qx_b0.pdf
included in SCFW Porting Kit
Hi nxf65583
