iMX8QXP Linux BSP Source
1,062 次查看
ogj
Where can I go to get the BSP source code (including drivers) for Linux for the iMX8X? I believe the latest image is L4.14.78_1.0.0, however this is just a pre-built image - not the source. I'm just getting started with developing with this processor so please forgive my ignorance.
标记 (1)
973 次查看
gusarambula
Hello Ken Green,
The latest Yocto BSP would be L4.14.98_2.2.0. The BSPs are delivered through Yocto, if you wish to build and customize your own image you would need to download the document bundle for this BSP.
The latest would be L4.14.98_2.2.0_LINUX_DOCS, available on the link below (you may need to login to download this file):
https://www.nxp.com/design/software/embedded-software/linux-software-and-development-tools/embedded-...
Inside the documentation you will find the i.MX Yocto Project User's Guide which shows how to setup your host to build the images.
I hope this information helps!
