I want to use TP-Link UB500 Bluetooth Dongle with iMX8QM EVK.
With Embedded Linux Kernel 6.1.1 prebuild image and
I was able to use my Bluetooth Dongle with Embedded Linux Kernel 5.15.32.
But I want to use my Bluetooth dongle with Android Automotive OS 12.
For this I followed the steps below.
1) The parameter "CONFIG_BT_HCIBTUSB=m" is set in the file "imx_v8_android_car_defconfig".
2) Android image was recompiled and flashed to the board.
3) A folder named "rtl_bt" has been created in the "/vendor/firmware" directory within the Image. In this folder "rtl8761bu_fw.bin"
The firmware has been discarded. Board rebooted.
These applied steps were also applied in Embedded Linux and the BLuetooth dongle worked in Linux.
But after following the steps I was not able to get my Bluetooth dongle working on Android Automotive OS 12.
Can you help me with this?
Best regards.
maybe you can refer to the chapter 8.4 Wi-Fi/Bluetooth configuration
"https://www.nxp.com.cn/docs/en/user-guide/ANDROID_USERS_GUIDE.pdf"
Hello @joanxie,
I went through the document you referenced but couldn't find a section on my problem.
What steps do I have to follow if I want to use a USB Bluetooth dongle with Android Automotive OS 12?
Best regards.
I don't find any special settings for this, maybe you can refer to the link as below:
"https://wiki.archlinux.org/title/bluetooth#Problems_with_all_BLE_devices_on_kernel_5.9+"
