‎06-02-2021
02:15 AM
charleshuang
Senior Contributor II
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Yocto zeus 5.4.70
I use imx8mq evk board and adv7535 bridge ic, but I can’t see the weston ui after booting up
I execute the following command then get weston service failed
root@imx8mqevk:~# systemctl -a | grep weston
* weston@root.service loaded failed failed Weston Wayland Compositor (on tty7)
Is this known issue?
Solved! Go to Solution.
‎06-03-2021
02:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎06-02-2021
06:58 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you attach your boot and kernel log?
‎06-02-2021
08:11 PM
charleshuang
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎06-02-2021
10:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which kind of images your are using? imx-image-multimedia? or imx-image-full
‎06-02-2021
10:16 PM
charleshuang
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We use imx-image-full
thanks
‎06-03-2021
02:12 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You need change card from card0 to card1 in weston.ini
