iMX8MQ Yocto Chromium configure fail.
bitglitcher
Dear NXP Support Team,
I'm trying to add chromium-ozone-wayland to our custom layer. The issue is that while doing so, the GN for chromium and qtwebengine seem to interfere. The only way that I can get qrwebengine to compile is by adding the following line to our layer.conf.
#BBMASK += "/meta-browser/meta-chromium/recipes-browser/chromium/gn-native_.*\.bb"
Now, by adding that line qtwebengine compiles just fine. But then Chromium fails to compile. Every include fails because it can't seem to find the library.
| In file included from ../../third_party/skia/src/core/SkGlyphRun.cpp:8:        | ../../third_party/skia/src/core/SkGlyphRun.h:11:10: fatal error: 'functional' file not found        | #include <functional>        |          ^~~~~~~~~~~~        | 1 error generated.
| In file included from ../../third_party/skia/src/core/SkBitmapDevice.cpp:8:        | In file included from ../../third_party/skia/include/core/SkImageFilter.h:11:        | In file included from ../../third_party/skia/include/core/SkFlattenable.h:11:        | In file included from ../../third_party/skia/include/core/SkRefCnt.h:11:        | In file included from ../../third_party/skia/include/core/SkTypes.h:192:        | In file included from ../../third_party/skia/../../skia/config/SkUserConfig.h:125:        | ../../skia/ext/skia_histogram.h:10:10: fatal error: 'atomic' file not found        | #include <atomic>        |          ^~~~~~~~
| ../../third_party/abseil-cpp/absl/status/status.h:54:10: fatal error: 'iostream' file not found        | #include <iostream>        |          ^~~~~~~~~~        | 1 error generated.
 Maybe I'm missing some dependency, or I need to declare something.
Benjamin Herrera Navarro
Zhiming_Liu
I think you should fix chromium and qtwebengine interfere issue refer the meta-freescale/conf/layer.conf:
