I have downloaded iMX8mq SDK for Cortex-M4 core and have tested its demo program successfully.
This sample program uses makefile for its building, but now I want to use mcuXpresso IDE for building and programming CM4 core.
Could you please share a sample project template for mcuXpresso so that I can use for my iMX8mq Cortex-M4 development?
IDE Version: MCUXpresso IDE v11.3.1
Thanks in advance
Solved! Go to Solution.
I could successfully create a sample cortex-m4 generic project in mcuXresso and build it
The i.MX SDK is not supported by the MCUXpresso IDE, with the exception of the i.MX RT, the toolchains supported are IAR and GCC ARM only.
Aldo.
I know it's not supported. I want to create a generic Cortex-M4 project in IDE and as the MCUXpresso compiler is gcc, so I can generate binary and elf files.
