iMX8MQ 8GB LPDDR4 part
1,899件の閲覧回数
ani10c89
As iMX8MQ supports upto 8GB LPDDR4 memory. Can you please suggest LPDDR4 8GB parts that are supported with iMX8M.
Anirudha
タグ(2)
3 返答(返信)
1,583件の閲覧回数
Yuri
  According to section 2.1.2 (Cortex-A53 Memory Map) of i.MX 8M Reference Manual, Rev. 0, 01/2018
only 4 GBytes address space is available for memory.
Yuri.
1,584件の閲覧回数
ani10c89
Hi Yuri,
As per i.MX 8M Reference Manual section 9.1.1.1, it says up to 8GB memory capacity.
So we assumed 8GB should not be a issue. Can you please reconfirm if 8GB LPDDR4 is not supported.
Anirudha
1,584件の閲覧回数
Yuri
  Section 9.1.1.1 concerns parameters of the DRAM controller as SNPS IP (taken separately by itself).
Restriction relates to address space, available for DRAM, in the i.MX8M SOC.
Yuri.
