iMX8MP-EVK: bitbake imx-image-core failed
已解决
跳至解决方案
2,696 次查看
jihoon-shin
Hi. I am asking for help because I have a problem.
I am proceeding with 3.1 Docker of 3. Host setup of i.MX Yocto Project User's Guide.
An error such as the photo below occurred while performing bitbake imx-image-core.스크린샷, 2022-04-28 09-17-50.pngThe work of 0:, 1: in the picture above never ends.
I've tried it again many times, but the results are the same.
What's the problem? Please help me.
1 解答
2,646 次查看
WolsYang
Please try to change URL in the recipe
From
KERNEL_SRC ?= "git://portland.source.codeauxxxxxxxxxxxxxxxxxxxx
To
KERNEL_SRC ?= "git://source.codeauxxxxxxxxxxxxxxx
And try again
在原帖中查看解决方案
7 回复数
2,688 次查看
WolsYang
I have the same problem.
I think there had some issue on the remote server.
2,678 次查看
jihoon-shin
Thanks. @WolsYang
Did you solve this problem?
If you have solved it, can you tell me the solution?
Or can I skip this step and proceed to the next step?
2,647 次查看
WolsYang
From
To
And try again
2,642 次查看
jihoon-shin
Thanks. @WolsYang
Is imx-image-core the recipe?
Please tell me the location of the imx-image-core.
2,639 次查看
WolsYang
You need to find yourself,
For example, if you are stuck at linux_imx do_fetch, probably the recipe is name linux-imx_xxxx.bb
And go find the SRC_URI change.
2,637 次查看
jihoon-shin
Thanks!!!! @WolsYang
I solved the problem!
2,674 次查看
WolsYang
Not yet, still stock at do_fetch.
I think should wait for NXP to check codeaurora connection.
