Hi!
When we keep the ONOFF for 5 seconds at zero volts, it goes into power off mode, but we continue to see some consumption (around 30mA) and some GPIO outputs with 900mV or 1V output voltage which polarizes some FETs.
Do you know what it is due to or how to avoid it?
Thanks in advance.
Solved! Go to Solution.
Solved!
There is a leakege that "powers" the iMX externally to the PMIC.
Solved!
