iMX8M Plus Pin Mapping Sheet
ReshmaRoy
Is there a IO Definition & Package Ballmap spreadsheet available for iMX 8M Plus SoC? If so, could you please tell me where can I find the same? It wasn't available with the datasheets or Reference Manual of iMX 8M plus.
Rita_Wang
For the ballmap I can share to you here, for the IO  Definition you can see in the configure tool, hope can do help for you.
Config Tools for i.MX Applications Processors | NXP Semiconductors
An error has occurred when reading existing sub-variable "Language_PG_Configuration"; see cause exception! The type of the containing value was: extended_hash+string (lithium.coreapi.webui.template.models.NamedValueByNameTemplateModel wrapped into f.e.b.StringModel) ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign redirect_lingo_page_url = web... [in template "language_macro_header.ftl" at line 173, column 1] - Reached through: #include "language_macro_header.ftl" [in template "Language_translator_Dashboard" at line 3, column 1] ----
