iMX8M Mini resources available to MCU
ソリューションへジャンプ
1,294件の閲覧回数
yfliu
Dear experts,
May I know what resources are avalable to the Cortex-M4 core in iMX8M mini SoC?  I mean DRAM memory ranges and peripherals? For example can M4 access PCI devices?
yf
1,236件の閲覧回数
JorgeCas
Yes, you can consult it in table Table 7-2. CM4 Interrupt Summary of reference manual:
Best regards.
5 返答(返信)
1,273件の閲覧回数
JorgeCas
You can consult this in section 2.1.3 Cortex-M4 Memory Map of reference manual.
Best regards.
1,263件の閲覧回数
yfliu
@JorgeCas thank you so much!
I saw both GIC and PCI in CM4 memory map. Does this mean that CM4 can also work with GIC for interruption handling? or CM4 just can only change settings and GIC interrupts are for CA53 cores?
yf
タグ(1)
1,258件の閲覧回数
JorgeCas
The interruption handling for Cortex-M is done with a Nested Vectored Interrupt Controller (NVIC) that is closely integrated with the processor core to achieve low-latency interrupt processing.
Best regards.
1,243件の閲覧回数
yfliu
@JorgeCasthank you again!
So can this CM4 receive interrupts from a PCI device?
yf
1,237件の閲覧回数
JorgeCas
Best regards.
