iMX8M Mini resources available to MCU
1,283 次查看
yfliu
Dear experts,
May I know what resources are avalable to the Cortex-M4 core in iMX8M mini SoC?  I mean DRAM memory ranges and peripherals? For example can M4 access PCI devices?
yf
1,225 次查看
JorgeCas
Yes, you can consult it in table Table 7-2. CM4 Interrupt Summary of reference manual:
Best regards.
5 回复数
1,262 次查看
JorgeCas
You can consult this in section 2.1.3 Cortex-M4 Memory Map of reference manual.
Best regards.
1,252 次查看
yfliu
@JorgeCas thank you so much!
I saw both GIC and PCI in CM4 memory map. Does this mean that CM4 can also work with GIC for interruption handling? or CM4 just can only change settings and GIC interrupts are for CA53 cores?
yf
标记 (1)
1,247 次查看
JorgeCas
The interruption handling for Cortex-M is done with a Nested Vectored Interrupt Controller (NVIC) that is closely integrated with the processor core to achieve low-latency interrupt processing.
Best regards.
1,232 次查看
yfliu
@JorgeCasthank you again!
So can this CM4 receive interrupts from a PCI device?
yf
1,226 次查看
JorgeCas
Best regards.
