iMX8M Mini - Is GP5 in the OTP eFuse map fully supported?
s_k
Is GP5 fully supported - can be used in the application reliably?
I would like to have this confirmed, as only GP1 and GP2 are described in the data sheet, GP5 is only briefly mentioned.
Stefan
Bio_TICFSL
Yes, it a general porpouse register you can use it.
Bio_TICFSL
Hello S_k,
You can find more information on Reference manual, and Security reference manual.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
s_k
Hello Bio_TICFSL,
Based on your hint I found Revision 3 of the Reference Manual.
This version includes the GP5_LOCK bits description, indeed.
However, Figure 6-28. OTP memory footprint on page 870 and the OCOTP memory map table on page 873 do not mention GP5, unlike GP1 and GP2.
Therefore, I would like to have confirmation from you whether our application is allowed to use GP5 without any restrictions.
Thank you.
Stefan
Bio_TICFSL
