iMX8 - mini , how to build freeRTOS simple project from the SDK's examples
moranmoran
My HW :  variscite EVB + dart-mx8m-mini som.
- I'm trying to prepare (on eclipse IDE) an environment for developing \ debugging the M4 (freertos) project.
- I've downloaded from MCUXpresso SDK builder --> SDK: 2.10.0.
I couldn't find any guide that explains how to build a full project tree from the SDK freeRTOS example projects.
The example projects include only sources w/o RTOS files.
Is there any full example (with all relevant folders)?
Thanks in advance,
Moran.
AldoG
You may refer to the document Getting Started with MCUXpresso SDK inside the package, you'll find this information in the chapter 2 MCUXpresso SDK board support folders.
Aldo.
moranmoran
Thanks, maybe my question wasn't clear enough.
I'm trying to set eclipse IDE as development & debug environment for M4 (IMX8).
Getting started with SDK structure doesn't help me to build the hello RTOS project on eclipse IDE.
Or I misunderstood something.
I'm sure I'm not the first one that tries to run this example on eclipse.
Thanks in advance,
Moran.
