Is the NXP supplied iMX8 SECO firmware having a PCKS#11 compatible/compliant interface for key management and manipulation? If not is that something that needs to be achieved via some middle ware?
Is there a place where I can find the SECO firmware API document, similar to the SCFW API documentation in the porting kit?
Hello i have the same question @Yuri can you please provide me also some information how to follow up?
Thank you in advance!
I also can not find the SECO API documentation, where is it located?
