We have to access an external SRAM with a 16Bit multiplexed Bus.
I have configurated all the Pins for external RAM and defined the EIM Registers . The Address vaild signal EIM_LBA_B now is low active.
How can I change EIM_LBA_B to high active? In my hardware is a address latch (ALE) high active, because this I needed the signal "inverted". Is there a possibility?
I configurated EIM_CS0GCR1, EIM_CS0GCR2, EIM_CS0RD1, EIM_CS0RD2.
best regards
