I am trying to update ota images over USB. OTA update done properly,I am following the below steps,
1. $source build/envsetup.sh
2. $lunch sabresd_6dq-user
3. $make otapackage -j4
And also I attached the document which one I followed for OTA.
1|sabresd_6dq:/mnt/media_rw/3B12-2DE7 #
sh usb-update.sh <
waiting for usb disk to be mounted *********
USB Mounted in /mnt/media_rw/3B12-2DE7 directory...!update.zip file foundNew Update file foundrm: /cache/update.zip: No such file or directoryhealthd: battery l=85 v=3 t=35.0 h=2 st=2 c=400 fc=4000000 cc=32 chg=a
Start update...!!!init: Received sys.powerctl='reboot,recovery' from pid: 1549 (reboot)
init: Clear action queue and start shutdown trigger
init: processing action (shutdown_done) from (<Builtin Action>:0)
init: Reboot start, reason: reboot,recovery, rebootTarget: recovery
init: Shutdown timeout: 6000 ms
init: starting service 'blank_screen'...
type=1400 audit(1568712360.600:8097): avc: denied { dac_read_search } for pid=248 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0 duplicate messages suppressed
init: terminating init services
type=1400 audit(1568712768.950:8107): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
init: Sending signal 15 to service 'wpa_supplicant' (pid 508) process group...
audit: audit_lost=7874 audit_rate_limit=5 audit_backlog_limit=64
audit: rate limit exceeded
init: Sending signal 15 to service 'perfprofd' (pid 282) process group...
init: Sending signal 15 to service 'gatekeeperd' (pid 281) process group...
Terminated
Terminated
143|sabresd_6dq:/mnt/media_rw/3B12-2DE7 # binder: release 243:243 transaction 60164 in, still active
binder: send failed reply for transaction 60164 to 375:442
binder: undelivered death notification, 000000008da7fbc0
binder: undelivered TRANSACTION_COMPLETE
binder: undelivered TRANSACTION_ERROR: 29189
binder: undelivered death notification, 00000000910c80c0
binder: undelivered death notification, 00000000910c8fc0
binder: undelivered death notification, 00000000a2817940
binder: undelivered death notification, 00000000910c8ac0
binder: undelivered death notification, 00000000a0a65500
binder: 508:508 transaction failed 29189/-22, size 116-8 line 3018
binder: 209:214 transaction failed 29189/-22, size 88-0 line 3018
type=1400 audit(1568712768.990:8111): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
audit: audit_lost=8093 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712770.070:8331): avc: denied { dac_read_search } for pid=209 comm="Binder:209_3" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
android_work: did not send uevent (0 0 (null))
logd.daemon: 7 output lines suppressed due to ratelimiting
ci_hdrc ci_hdrc.1: remove, state 4
usb usb2: USB disconnect, device number 1
ci_hdrc ci_hdrc.1: USB bus 2 deregistered
ci_hdrc ci_hdrc.0: remove, state 1
usb usb1: USB disconnect, device number 1
usb 1-1: USB disconnect, device number 4
ci_hdrc ci_hdrc.0: USB bus 1 deregistered
imx2-wdt 20c0000.wdog: Device shutdown: Expect reboot!
reboot: Restarting system with command 'recovery' U-Boot 2018.03-00001-g2307a2c (Aug 30 2019 - 18:00:34 +0530)
CPU: Freescale i.MX6Q rev1.3 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C) at 37C
Reset cause: POR
Model: Freescale i.MX6 Quad SABRE Smart Device Board
Board: MX6-SabreSD
DRAM: 1 GiB
PMIC: PFUZE100! DEV_ID=0x10 REV_ID=0x21
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
flash target is MMC:2
Net:
Warning: ethernet@02188000 using MAC address from ROM
eth0: ethernet@02188000 [PRIME]
Fastboot: Got Recovery key pressing or recovery commands!
setup env for recovery..
Normal Boot
Hit any key to stop autoboot: 0
Will boot from recovery!
RNG already instantiated 0x40000003
verify OK, boot 'recovery'
kernel @ 14008000 (10182008)
ramdisk @ 15000000 (6254318)
fdt @ 14f00000 (54510)
## Booting Android Image at 0x14007800 ...
Kernel load addr 0x14008000 size 9944 KiB
## Flattened Device Tree blob at 14f00000
Booting using the fdt blob at 0x14f00000
XIP Kernel Image ... OK
Using Device Tree in place at 14f00000, end 14f104ed
switch to ldo_bypass mode!
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.14.98 (saispandana@saispandana-VirtualBox) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #1 SMP PREEMPT Wed Aug 28 00:31:41 IST 2019
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
Memory policy: Data cache writealloc
cma: Reserved 320 MiB at 0x2a000000
random: get_random_bytes called from start_kernel+0xac/0x450 with crng_init=0
percpu: Embedded 18 pages/cpu @f6de6000 s41292 r8192 d24244 u73728
Built 1 zonelists, mobility grouping on. Total pages: 260146
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=userdebug androidboot.serialno=1c1eb9d4ea98b4f1 androidboot.btmacaddr=1c:1e:b9:d4:ea:98 androidboot.soc_type=imx6q androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:2204,KL:0,KD:0,AVB:1289,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=aaa977ed-b57a-46bf-b801-7522c14aedd4 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=2944 androidboot.vbmeta.digest=13512be366e5f32b076b7dffc30c7a7da478752eafc72be83c96b0dfe957f30b androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.key
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 681536K/1048576K available (13312K kernel code, 1057K rwdata, 4060K rodata, 1024K init, 504K bss, 39360K reserved, 327680K cma-reserved, 139264K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf8000000 - 0xff800000 ( 120 MB)
lowmem : 0xc0000000 - 0xf7800000 ( 888 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc0e00000 (14304 kB)
.init : 0xc1300000 - 0xc1400000 (1024 kB)
.data : 0xc1400000 - 0xc1508550 (1058 kB)
.bss : 0xc150a000 - 0xc1588348 ( 505 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
ftrace: allocating 41814 entries in 123 pages
Tasks RCU enabled.
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
L2C-310 errata 752271 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 16 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 1024 kB
L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
Switching to timer-based delay loop, resolution 333ns
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Security Framework initialized
SELinux: Initializing.
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU0: Spectre v2: using BPIALL workaround
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10100000 - 0x10100060
Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
CPU1: Spectre v2: using BPIALL workaround
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
CPU2: Spectre v2: using BPIALL workaround
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
CPU3: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 4 CPUs
SMP: Total of 4 processors activated (24.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
CPU3: update max cpu_capacity 1024
devtmpfs: initialized
CPU2: update max cpu_capacity 1024
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 1024 (order: 4, 65536 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.5
vdd1p1: supplied by regulator-dummy
vdd3p0: supplied by regulator-dummy
vdd2p5: supplied by regulator-dummy
vddarm: bypassed regulator has no supply!
vddarm: failed to get the current voltage(-517)
vddsoc: bypassed regulator has no supply!
vddsoc: failed to get the current voltage(-517)
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins or pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/gpio_leds/gpioledsgrp
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
imx rpmsg driver is registered.
pstore: using zlib compression
console [pstore-1] enabled
pstore: Registered ramoops as persistent store backend
ramoops: attached 0x100000@0x3ff00000, ecc: 0/0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb_phy_generic 2000000.aips-bus:usbphy_nop1: 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
usb_phy_generic 2000000.aips-bus:usbphy_nop2: 2000000.aips-bus:usbphy_nop2 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-0: can't use DMA, using PIO instead.
i2c i2c-1: IMX I2C adapter registered
i2c i2c-1: can't use DMA, using PIO instead.
i2c i2c-2: IMX I2C adapter registered
i2c i2c-2: can't use DMA, using PIO instead.
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.22
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
clocksource: Switched to clocksource mxc_timer1
VFS: Disk quotas dquot_6.6.0
VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 6108K
hw perfevents: no interrupt-affinity property for /soc/pmu, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
Bus freq driver module loaded
audit: initializing netlink subsys (disabled)
audit: type=2000 audit(0.960:1): state=initialized audit_enabled=0 res=1
workingset: timestamp_bits=14 max_order=18 bucket_order=4
Registering sdcardfs 0.1
jffs2: version 2.2. (NAND) Â
2001-2006 Red Hat, Inc.
fuse init (API version 7.26)
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler mq-deadline registered
io scheduler kyber registered
pwm-backlight backlight: backlight supply power not found, using dummy regulator
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
fbcvt: 1920x1080@60: CVT Name - 2.073M9
mxc_sdc_fb fb@0: registered mxc display driver hdmi
imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 240x67
mxc_sdc_fb fb@1: Can't get fb option for mxcfb1!
mxc_sdc_fb fb@2: Can't get fb option for mxcfb2!
mxc_sdc_fb fb@3: Can't get fb option for mxcfb3!
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: Falling back to user helper
mxs-dma 110000.dma-apbh: initialized
imx-pgc-pd imx-pgc-power-domain.0: Linked as a consumer to 20dc000.gpc
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 27, base_baud = 5000000) is a IMX
console [ttymxc0] enabled
21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 75, base_baud = 5000000) is a IMX
imx sema4 driver is registered.
[drm] Initialized vivante 1.0.0 20120216 for platform:Vivante GCCore on minor 0
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
zram: Added device: zram0
libphy: Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
CAN device driver interface
fec 2188000.ethernet: 2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
usbcore: registered new interface driver kaweth
pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver r8152
usbcore: registered new interface driver asix
usbcore: registered new interface driver ax88179_178a
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver cdc_ncm
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb_ehset_test
usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
usb_otg_vbus: supplied by SWBST
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 4.14.98 ehci_hcd
usb usb1: SerialNumber: ci_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb_h1_vbus: supplied by SWBST
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 4.14.98 ehci_hcd
usb usb2: SerialNumber: ci_hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usbcore: registered new interface driver xpad
usbcore: registered new interface driver usb_acecad
usbcore: registered new interface driver aiptek
usbcore: registered new interface driver gtco
usbcore: registered new interface driver hanwang
usbcore: registered new interface driver kbtab
egalax_ts 1-0004: Failed to switch to I2C interface
usb 1-1: new high-speed USB device number 2 using ci_hdrc
egalax_ts 2-0004: Failed to switch to I2C interface
egalax_ts: probe of 2-0004 failed with error -110
usb 1-1: New USB device found, idVendor=0781, idProduct=5539
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1: Product: Cruzer Micro
usb 1-1: Manufacturer: SanDisk
usb 1-1: SerialNumber: 240102165112CC1E
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1:1.0
input: max11801_ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-0048/input/input2
snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x/sz) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR SANYO protocol handler initialized
IR Sharp protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
IR XMP protocol handler initialized
mxc_v4l2_output v4l2_out: V4L2 device registered as video16
mxc_v4l2_output v4l2_out: V4L2 device registered as video17
ov5640_read_reg:write reg error:reg=300a
camera ov5640 is not found
ov5642_read_reg:write reg error:reg=300a
camera ov5642 is not found
camera ov5640_mipi is not found
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
__power_supply_register: Expected proper parent device for 'battery'
(NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
__power_supply_register: Expected proper parent device for 'usb'
mag3110 2-000e: check mag3110 chip ID
input: FreescaleMagnetometer as /devices/virtual/input/input3
input: eCompass as /devices/virtual/input/input4
random: fast init done
mag3110 2-000e: mag3110 is probed
input: FreescaleAccelerometer as /devices/virtual/input/input5
mma8x5x device driver probe successfully
imx2-wdt 20c0000.wdog: timeout 60 sec (nowayout=0)
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
Bluetooth: HCI UART driver ver 2.3
Bluetooth: HCI UART protocol H4 registered
Bluetooth: HCI UART protocol BCSP registered
Bluetooth: HCI UART protocol ATH3K registered
bt power gpio is:2
rfkill: BT RF going to : on
mxc_bt_rfkill_reset
mxc_bt_rfkill driver success loaded
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
sdhci-esdhc-imx 2194000.usdhc: allocated mmc-pwrseq
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
sdhci-esdhc-imx 2198000.usdhc: Got CD GPIO
sdhci-esdhc-imx 2198000.usdhc: Got WP GPIO
mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
mmc1: queuing unknown CIS tuple 0x80 (6 bytes)
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
scsi 0:0:0:0: Direct-Access SanDisk Cruzer Micro 8.02 PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: [sda] 7856127 512-byte logical blocks: (4.02 GB/3.75 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mmc1: new high speed SDIO card at address 0001
sda: sda1
mxc_hdmi_cec soc:hdmi_cec@00120000: HDMI CEC initialized
sd 0:0:0:0: [sda] Attached SCSI removable disk
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
ashmem: initialized
usbcore: registered new interface driver snd-usb-audio
wm8962 0-001a: customer id 0 revision D
fsl-ssi-dai 202c000.ssi: No cache defaults, reading back from HW
input: WM8962 Beep Generator as /devices/soc0/soc/2100000.aips-bus/21a0000.i2c/i2c-0/0-001a/input/input6
mmc3: new DDR MMC card at address 0001
mmcblk3: mmc3:0001 Q2J55L 7.13 GiB
mmcblk3boot0: mmc3:0001 Q2J55L partition 1 2.00 MiB
mmcblk3boot1: mmc3:0001 Q2J55L partition 2 2.00 MiB
mmcblk3rpmb: mmc3:0001 Q2J55L partition 3 4.00 MiB
Alternate GPT is invalid, using primary GPT.
mmcblk3: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13
imx-wm8962 sound: wm8962 <-> 202c000.ssi mapping ok
imx-wm8962 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
imx-audio-hdmi sound-hdmi: i2s-hifi <-> soc:hdmi_audio@00120000 mapping ok
NET: Registered protocol family 26
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
ctnetlink v0.93: registering with nfnetlink.
xt_time: kernel timezone is -0000
IPv4 over IPsec tunneling driver
ip_tables: (C) 2000-2006 Netfilter Core Team
arp_tables: arp_tables: (C) 2002 David S. Miller
Initializing XFRM netlink socket
NET: Registered protocol family 10
Segment Routing with IPv6
mip6: Mobile IPv6
ip6_tables: (C) 2000-2006 Netfilter Core Team
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 15
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20170425) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
lib80211: common routines for IEEE802.11 drivers
vddpu: supplied by SW1C
registered taskstats version 1
vddarm: supplied by SW1AB
vddsoc: supplied by SW1C
imx-pgc-pd imx-pgc-power-domain.1: Linked as a consumer to 20dc000.gpc
mxc_vpu 2040000.vpu_fsl: VPU initialized
Galcore version 6.2.4.190076
[drm] Initialized vivante 1.0.0 20170808 for 130000.gpu on minor 1
Hot alarm is canceled. GPU3D clock will return to 64/64
imx_thermal 2000000.aips-bus:tempmon: Automotive CPU temperature grade - max:125C critical:120C passive:115C
input: gpio-keys as /devices/soc0/gpio-keys/input/input9
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2019-09-17 09:32:59 UTC (1568712779)
wm8962-supply: disabling
VGEN1: disabling
ALSA device list:
#0: wm8962-audio
#1: imx-hdmi-soc
Freeing unused kernel memory: 1024K
init: init first stage started!
init: First stage mount skipped (recovery mode)
init: Using Android DT directory /proc/device-tree/firmware/android/
init: [libfs_mgr]Returning avb_handle with status: 0
init: Loading SELinux policy
SELinux: Class process2 not defined in policy.
SELinux: Class infiniband_pkey not defined in policy.
SELinux: Class infiniband_endport not defined in policy.
SELinux: the above unknown classes and permissions will be denied
SELinux: policy capability network_peer_controls=1
SELinux: policy capability open_perms=1
SELinux: policy capability extended_socket_class=1
SELinux: policy capability always_check_network=0
SELinux: policy capability cgroup_seclabel=0
SELinux: policy capability nnp_nosuid_transition=0
audit: type=1403 audit(1568712779.960:2): policy loaded auid=4294967295 ses=4294967295
selinux: SELinux: Loaded policy from /sepolicy
audit: type=1404 audit(1568712779.970:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
selinux: SELinux: Loaded file_contexts
init: init second stage started!
init: Running restorecon...
init: waitid failed: No child processes
init: Couldn't load property file '/system/etc/prop.default': open() failed: No such file or directory: No such file or directory
init: Unable to set property 'ro.product.first_api_level' to '26' in property file '/prop.default': Read-only property was already set
init: Couldn't load property file '/product/build.prop': open() failed: No such file or directory: No such file or directory
init: Couldn't load property file '/odm/default.prop': open() failed: No such file or directory: No such file or directory
init: Couldn't load property file '/vendor/default.prop': open() failed: No such file or directory: No such file or directory
audit: type=1400 audit(1568712780.190:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: ueventd started!
audit: type=1400 audit(1568712780.190:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712780.190:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: Parsing file /ueventd.rc...
audit: type=1400 audit(1568712780.190:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712780.190:8): avc: denied { create } for pid=1 comm="init" name="cgroup.procs" scontext=u:r:init:s0 tcontext=u:object_r:rootfs:s0 tclass=file permissive=0
ueventd: Parsing file /vendor/ueventd.rc...
ueventd: Unable to read config file '/vendor/ueventd.rc': open() failed: No such file or directory
ueventd: Parsing file /odm/ueventd.rc...
ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory
ueventd: Parsing file /ueventd.freescale.rc...
ueventd: Unable to read config file '/ueventd.freescale.rc': open() failed: No such file or directory
ueventd: firmware: loading 'imx/sdma/sdma-imx6q.bin' for '/devices/soc0/soc/2000000.aips-bus/20ec000.sdma/firmware/imx!sdma!sdma-imx6q.bin'
audit: type=1400 audit(1568712780.540:9): avc: denied { write } for pid=1 comm="init" name="cursor_blink" dev="sysfs" ino=9008 scontext=u:r:init:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=0
file system registered
audit: type=1400 audit(1568712780.570:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
android.hardware.health@2.0-impl: wakealarm_init: timerfd_create failed
read descriptors
imx-sdma 20ec000.sdma: external firmware not found, using ROM firmware
EXT4-fs (mmcblk3p5): Ignoring removed nomblk_io_submit option
read strings
EXT4-fs (mmcblk3p5): mounted filesystem with ordered data mode. Opts: nomblk_io_submit
kauditd_printk_skb: 15 callbacks suppressed
audit: type=1400 audit(1568712780.650:26): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712780.680:27): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712780.700:28): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712780.700:29): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712782.960:30): avc: denied { read } for pid=162 comm="recovery" name="power_supply" dev="sysfs" ino=9501 scontext=u:r:recovery:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=0
audit: type=1400 audit(1568712782.960:31): avc: denied { write } for pid=162 comm="recovery" name="kmsg" dev="tmpfs" ino=7253 scontext=u:r:recovery:s0 tcontext=u:object_r:kmsg_device:s0 tclass=chr_file permissive=0
audit: type=1400 audit(1568712783.020:32): avc: denied { read } for pid=162 comm="recovery" name="thermal" dev="sysfs" ino=10632 scontext=u:r:recovery:s0 tcontext=u:object_r:sysfs:s0 tclass=dir permissive=0
audit: type=1400 audit(1568712783.140:33): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.250:34): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.260:35): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.260:36): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.260:37): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.260:38): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.290:39): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.290:40): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.290:41): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.290:42): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712791.290:43): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
random: crng init done
kauditd_printk_skb: 1 callbacks suppressed
audit: type=1400 audit(1568712872.050:45): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:46): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:47): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:48): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:49): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:50): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.050:51): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.590:52): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.590:53): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712872.590:54): avc: denied { dac_read_search } for pid=175 comm="update-binary" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
kauditd_printk_skb: 14 callbacks suppressed
audit: type=1400 audit(1568712880.040:69): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712880.040:70): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: audit_backlog=65 > audit_backlog_limit=64
audit: type=1400 audit(1568712880.060:71): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
audit: backlog limit exceeded
audit: type=1400 audit(1568712880.060:72): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712880.060:73): avc: denied { dac_read_search } for pid=162 comm="recovery" capability=2 scontext=u:r:recovery:s0 tcontext=u:r:recovery:s0 tclass=capability permissive=0
audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=64
init: Received sys.powerctl='reboot,' from pid: 162 (/sbin/recovery)
init: Reboot start, reason: reboot,, rebootTarget:
init: Sending signal 15 to service 'recovery' (pid 162) process group...
init: Sending signal 15 to service 'charger' (pid 161) process group...
init: Sending signal 15 to service 'ueventd' (pid 155) process group...
libprocessgroup: Failed to open process cgroup uid 0 pid 155: No such file or directory
usb 1-1: USB disconnect, device number 2
reboot: Restarting system with command '' U-Boot 2018.03-00001-g2307a2c (Aug 30 2019 - 18:00:34 +0530)
CPU: Automotive temperature grade (-40C to 125C) at 38C
Reset cause: POR
Board: MX6-SabreSD
DRAM: 1 GiB
Failed (-5)
In: serial
Out: serial
Err: serial
Net:
Fastboot: Normal
Normal Boot
verify OK, boot 'boot'
kernel @ 14008000 (10181720)
ramdisk @ 15000000 (1800208)
Starting kernel ...
Linux version 4.14.98-dirty (root@Mark40) (gcc version 4.9.x 20150123 (prerelease) (GCC)) #3 SMP PREEMPT Tue Sep 17 11:55:21 IST 2019
Kernel command line: console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb,fbpix=RGB32,bpp=32 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=128M androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=320M galcore.contiguousSize=33554432 loop.max_part=7 buildvariant=user androidboot.serialno=1c1eb9d4ea98b4f1 androidboot.btmacaddr=1c:1e:b9:d4:ea:98 androidboot.soc_type=imx6q androidboot.storage_type=emmc androidboot.boottime=1BLL:0,1BLE:1834,KL:0,KD:0,AVB:959,ODT:0,SW:0 androidboot.bootreason=cold,powerkey androidboot.verifiedbootstate=green androidboot.slot_suffix= androidboot.vbmeta.device=PARTUUID=aaa977ed-b57a-46bf-b801-7522c14aedd4 androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=locked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=3008 androidboot.vbmeta.digest=02d95464f1d8120749185a22911ed5d40f0758694ef5462e7359376e8679327b androidboot.veritymode=enforcing androidboot.dtbo_idx=0 androidboot.keystore=sof
Memory: 685884K/1048576K available (13312K kernel code, 1057K rwdata, 4060K rodata, 1024K init, 504K bss, 35012K reserved, 327680K cma-reserved, 139264K highmem)
Tasks RCU enabled.
Freeing initrd memory: 1760K
audit: type=2000 audit(0.710:1): state=initialized audit_enabled=0 res=1
mxc_sdc_fb fb@0: registered mxc display driver ldb
imx-ipuv3 2800000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
brd: module loaded
loop: module loaded
usb usb1: Manufacturer: Linux 4.14.98-dirty ehci_hcd
usb usb2: Manufacturer: Linux 4.14.98-dirty ehci_hcd
bt power gpio is:2
mxc_bt_rfkill_reset
sda: sda1
ashmem: initialized
fsl-hdmi-dai soc:hdmi_audio@00120000: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of soc:hdmi_audio@00120000 failed with error -12
imx-audio-hdmi sound-hdmi: initialize HDMI-audio failed. load HDMI-video first!
u32 classifier
Actions configured
mip6: Mobile IPv6
snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2019-09-17 09:34:51 UTC (1568712891)
VGEN1: disabling
ALSA device list:
#0: wm8962-audio
init: [libfs_mgr]fs_mgr_read_fstab_default(): failed to find device default fstab
init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/system /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/system 4096 4096 451493 451493 sha1 da46fb8c9c8cb09eb5bfa3a5260031a78937bcc5 642e6fa491cfc97bbd81683a3c91f598dcbbffa144e70f25e54ba8a521483193 10 use_fec_from_device /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/system fec_roots 2 fec_blocks 455050 fec_start 455050 restart_on_corruption ignore_zero_blocks'
EXT4-fs (dm-0): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
init: [libfs_mgr]__mount(source=/dev/block/dm-0,target=/system,type=ext4)=0: Success
init: [libfs_mgr]Loading verity table: '1 /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/vendor /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/vendor 4096 4096 28199 28199 sha1 ccdcf9e4a9fb7c87d1644fe7304c2974d3c69b9c 642e6fa491cfc97bbd81683a3c91f598dcbbffa144e70f25e54ba8a521483193 10 use_fec_from_device /dev/block/platform/soc0/soc/2100000.aips-bus/219c000.usdhc/by-name/vendor fec_roots 2 fec_blocks 28423 fec_start 28423 restart_on_corruption ignore_zero_blocks'
EXT4-fs (dm-1): mounted filesystem without journal. Opts: barrier=1,inode_readahead_blks=8
init: [libfs_mgr]__mount(source=/dev/block/dm-1,target=/vendor,type=ext4)=0: Success
init: Skipped setting INIT_AVB_VERSION (not in recovery mode)
audit: type=1403 audit(1568712892.180:2): policy loaded auid=4294967295 ses=4294967295
audit: type=1404 audit(1568712892.180:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
init: 2 output lines suppressed due to ratelimiting
init: Created socket '/dev/socket/property_service', mode 666, user 0, group 0
init: Forked subcontext for 'u:r:vendor_init:s0' with pid 169
init: Forked subcontext for 'u:r:vendor_init:s0' with pid 171
init: Parsing file /init.rc...
audit: type=1400 audit(1568712892.490:4): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.490:5): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.490:6): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.490:7): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.500:8): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.500:9): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.500:10): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
ueventd: loading /devices/soc0/soc/2000000.aips-bus/20ec000.sdma/firmware/imx!sdma!sdma-imx6q.bin took 29ms
imx-sdma 20ec000.sdma: loaded firmware 3.4
audit: type=1400 audit(1568712892.930:12): avc: denied { write } for pid=1 comm="init" name="alignment" dev="proc" ino=4026531987 scontext=u:r:init:s0 tcontext=u:object_r:proc:s0 tclass=file permissive=0
audit: type=1400 audit(1568712892.960:13): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
watchdogd: watchdogd started (interval 10, margin 20)!
audit: type=1400 audit(1568712892.960:14): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712892.960:15): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
Console: switching
audit: type=1400 audit(1568712892.960:16): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
to colour dummy device 80x30
EXT4-fs (mmcblk3p11): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk3p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,noauto_da_alloc,errors=panic
audit: type=1400 audit(1568712893.140:17): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712893.150:18): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac4339-sdio.bin for chip 0x004339(17209) rev 0x000002
audit: type=1400 audit(1568712893.150:19): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
brcmfmac mmc1:0001:1: Falling back to user helper
audit: type=1400 audit(1568712893.150:20): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
audit: type=1400 audit(1568712893.150:21): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
zram0: detected capacity change from 0 to 536870912
logd.auditd: start
mkswap: Swapspace size: 524284k, UUID=db539291-ce63-43e8-86ae-a0b03a0a8423
Adding 524284k swap on /dev/block/zram0. Priority:-2 extents:1 across:524284k SS
type=1400 audit(1568712893.380:45): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
fscrypt: Adiantum using implementation "adiantum(xchacha12-neon,aes-arm,nhpoly1305-neon)"
rfkill: BT RF going to : off
logd.daemon: reinit
brcmfmac: brcmf_c_process_clm_blob: no clm_blob available(err=-11), device may have limited channels available
brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 7 2018 06:16:29 version 6.37.39.92 (r683655 CY)
Mass Storage Function, version: 2009/09/11
LUN: removable file: (no medium)
using random self ethernet address
using random host ethernet address
brcmfmac: brcmf_sdio_ulp_preinit: ulp_sdioctrl iovar returned err = -23
type=1400 audit(1568712894.420:370): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712895.670:484): avc: denied { read } for pid=244 comm="usb@1.1-service" name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=12365 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0
ERROR: v4l2 capture: slave not found!
init: Received control message 'start' for 'bootanim' from pid: 246 (/system/bin/surfaceflinger)
init: starting service 'bootanim'...
type=1400 audit(1568712895.760:488): avc: denied { read } for pid=244 comm="usb@1.1-service" name="u:object_r:ffs_prop:s0" dev="tmpfs" ino=12365 scontext=u:r:hal_usb_impl:s0 tcontext=u:object_r:ffs_prop:s0 tclass=file permissive=0 duplicate messages suppressed
type=1400 audit(1568712897.810:504): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0
type=1400 audit(1568712897.810:507): avc: denied { dac_read_search } for pid=1 comm="init" capability=2 scontext=u:r:init:s0 tcontext=u:r:init:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712898.420:508): avc: denied { dac_read_search } for pid=268 comm="applypatch" capability=2 scontext=u:r:install_recovery:s0 tcontext=u:r:install_recovery:s0 tclass=capability permissive=0
applypatch (348): drop_caches: 3
capability: warning: `main' uses 32-bit capabilities (legacy support in use)
init: Service 'flash_recovery' (pid 253) exited with status 0
type=1400 audit(1568712908.810:509): avc: denied { dac_read_search } for pid=221 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
type=1400 audit(1568712908.810:510): avc: denied { dac_read_search } for pid=221 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
audit_log_lost: 29 callbacks suppressed
audit: audit_lost=441 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712913.800:511): avc: denied { dac_read_search } for pid=256 comm="Binder:256_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
type=1400 audit(1568712913.810:518): avc: denied { dac_read_search } for pid=256 comm="Binder:256_1" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
audit: audit_lost=2693 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712914.860:2771): avc: denied { dac_read_search } for pid=256 comm="Binder:256_2" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
period 0 ,timeout is 0, wake up is :smileylaugh:
init: processing action (sys.sysctl.extra_free_kbytes=*) from (/init.rc:725)
audit: audit_lost=3346 audit_rate_limit=5 audit_backlog_limit=64
read descriptors
read strings
read descriptors
read strings
acc_open
acc_release
Generic PHY 2188000.ethernet-1:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet-1:01, irq=POLL)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
cgroup: main (532) created nested cgroup for controller "memory" which has incomplete hierarchy support. Nested cgroups may change behavior in the future.
cgroup: "memory" requires setting use_hierarchy to 1 on the root
type=1400 audit(1568712915.870:3433): avc: denied { dac_read_search } for pid=256 comm="Binder:256_2" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712923.780:3506): avc: denied { dac_read_search } for pid=532 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
audit: audit_lost=3418 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712923.780:3509): avc: denied { dac_read_search } for pid=532 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712923.850:3510): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0
init: Received control message 'start' for 'wpa_supplicant' from pid: 261 (/system/bin/wificond)
init: starting service 'wpa_supplicant'...
sdcardfs version 2.0
sdcardfs: dev_name -> /data/media
sdcardfs: options -> fsuid=1023,fsgid=1023,multiuser,derive_gid,default_normal,mask=6,userid=0,gid=1015
init: Created socket '/dev/socket/wpa_wlan0', mode 660, user 1010, group 1010
sdcardfs: mnt -> f55b5b10
sdcardfs: mounted on top of /data/media type ext4
Remount options were mask=23,gid=9997 for vfsmnt f596f210.
sdcardfs : options - debug:1
sdcardfs : options - gid:9997
sdcardfs : options - mask:23
Remount options were mask=7,gid=9997 for vfsmnt f59cdb10.
sdcardfs : options - mask:7
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
type=1400 audit(1568712925.590:3534): avc: denied { dac_read_search } for pid=731 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
type=1400 audit(1568712925.590:3537): avc: denied { dac_read_search } for pid=731 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0 duplicate messages suppressed
audit: audit_lost=3441 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712925.710:3538): avc: denied { dac_read_search } for pid=746 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
mxc_bt_rfkill_reset
FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
type=1400 audit(1568712928.150:3548): avc: denied { dac_read_search } for pid=206 comm="Binder:206_2" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0
period 66 ,timeout is 0, wake up is :smileylaugh:
mma enable setting active
init: Service 'bootanim' (pid 339) exited with status 0
init: Received control message 'stop' for 'adbd' from pid: 367 (system_server)
init: processing action (init.svc.adbd=stopped) from (/init.usb.configfs.rc:14)
init: processing action (sys.boot_completed=1) from (/init.rc:719)
init: processing action (sys.boot_completed=1) from (/vendor/etc/init/hw/init.freescale.rc:140)
init: processing action (sys.boot_completed=1 && sys.logbootcomplete=1) from (/system/etc/init/bootstat.rc:70)
audit: audit_lost=3450 audit_rate_limit=5 audit_backlog_limit=64
init: starting service 'exec 4 (/system/bin/bootstat --set_system_boot_reason --record_boot_complete --record_boot_reason --record_time_since_factory_reset -l)'...
init: processing action (sys.boot_completed=1 && sys.wifitracing.started=0) from (/system/etc/init/wifi-events.rc:20)
init: Command 'mkdir /sys/kernel/debug/tracing/instances/wifi 711' action=sys.boot_completed=1 && sys.wifitracing.started=0 (/system/etc/init/wifi-events.rc:22) took 179ms and succeeded
selinux: SELinux: Skipping restorecon_recursive(/data/system_ce/0)
type=1400 audit(1568712931.290:3557): avc: denied { dac_read_search } for pid=206 comm="Binder:206_2" capability=2 scontext=u:r:vold:s0 tcontext=u:r:vold:s0 tclass=capability permissive=0 duplicate messages suppressed
audit: audit_lost=4753 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712932.300:4861): avc: denied { dac_read_search } for pid=256 comm="Binder:256_6" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0
type=1400 audit(1568712932.300:4865): avc: denied { dac_read_search } for pid=256 comm="Binder:256_6" capability=2 scontext=u:r:installd:s0 tcontext=u:r:installd:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712933.360:4957): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0
audit: audit_lost=4844 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712933.360:4960): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0 duplicate messages suppressed
type=1400 audit(1568712933.460:4961): avc: denied { dac_read_search } for pid=1019 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
type=1400 audit(1568712934.390:5029): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0
audit: audit_lost=4916 audit_rate_limit=5 audit_backlog_limit=64
audit: audit_lost=4965 audit_rate_limit=5 audit_backlog_limit=64
init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/init.rc:729)
audit: audit_lost=4985 audit_rate_limit=5 audit_backlog_limit=64
audit: audit_lost=4992 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712941.780:5138): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0 duplicate messages suppressed
audit: audit_lost=4997 audit_rate_limit=5 audit_backlog_limit=64
type=1400 audit(1568712941.810:5139): avc: denied { dac_read_search } for pid=1209 comm="main" capability=2 scontext=u:r:zygote:s0 tcontext=u:r:zygote:s0 tclass=capability permissive=0
type=1400 audit(1568712945.830:5183): avc: denied { dac_read_search } for pid=245 comm="lmkd" capability=2 scontext=u:r:lmkd:s0 tcontext=u:r:lmkd:s0 tclass=capability permissive=0
audit: audit_lost=5040 audit_rate_limit=5 audit_backlog_limit=64
VinothS.
