iMX6UL DDR3 layout question
mengxp
Hi all,
the DDR3 layout detail in iMX6UL design guide is not clear for me
so I read the IMX6UL 14x14 EVK board file LAY-28617_C2.brd
following table is the DDR3 trace length I extract from Altium
DRAM_SDCLK0_N1474.547
DRAM_SDCLK0_P1478.036
DRAM_ADDR01456.372
DRAM_ADDR11383.264
DRAM_ADDR21383.865
DRAM_ADDR31377.21minimum
DRAM_ADDR41460.093
DRAM_ADDR51385.589
DRAM_ADDR61385.052
DRAM_ADDR71468.929
DRAM_ADDR81456.697
DRAM_ADDR91389.506
DRAM_ADDR101463.336
DRAM_ADDR111455.482
DRAM_ADDR121457.502
DRAM_ADDR131489.418
DRAM_ADDR141381.572
DRAM_ADDR151455.742
DRAM_SDBA01391.499
DRAM_SDBA11378.845
DRAM_SDBA21392.906
DRAM_RAS_B1456.112
DRAM_CAS_B1396.785
DRAM_SDWE_B1379.31
DRAM_CS0_B1397.098
DRAM_CS1_B1457.976
DRAM_SDCKE01500.327maximum
DRAM_SDCKE11475.134
DRAM_ODT01388.913
DRAM_ODT11456.594
DRAM_RESET_B1394.69
DRAM_SDQS0_N1111.194
DRAM_SDQS0_P1110.196
DRAM_DQM0992.587
DRAM_DATA0991.092
DRAM_DATA1997.784
DRAM_DATA2998.88
DRAM_DATA3992.781
DRAM_DATA4998.4
DRAM_DATA5998.351
DRAM_DATA6995.83
DRAM_DATA7997.645
DRAM_SDQS1_N1024.715
DRAM_SDQS1_P1023.824
DRAM_DQM11019.876
DRAM_DATA81021.889
DRAM_DATA91020.667
DRAM_DATA101025.673
DRAM_DATA111029.274
DRAM_DATA121027.033
DRAM_DATA131025.052
DRAM_DATA141025.595
DRAM_DATA151022.981
most of the signals trace length is reasonable
but the SDQS0_P/SDQS0_N is a question ,why they are traced about ~1110 mil?
should they trace to ~1000 mil around?
and following picture is SDQS0_P/SDQS0_N trace, they can be traced to ~1000,
why 1110 mil?
Yuri
@mengxp
  according to Table 22 (DDR3 routing by byte group) of Hardware Development Guide
signals in byte group should match the signals of each byte group ± 25 mils.
Match the differential signals of DQS ± 10 mils
https://www.nxp.com/webapp/Download?colCode=IMX6ULHDG
  Looks like no problem in Your case.
Yuri.
mengxp
and these is my DDR3 trace length, is this ok?
DRAM_CLK0_N677.746
DRAM_CLK0_P676.912
DRAM_ADDR0677.742
DRAM_ADDR1676.138
DRAM_ADDR2677.506
DRAM_ADDR3677.819
DRAM_ADDR4677.513
DRAM_ADDR5678.519
DRAM_ADDR6674.767
DRAM_ADDR7678.011
DRAM_ADDR8677.046
DRAM_ADDR9678.917
DRAM_ADDR10677.574
DRAM_ADDR11677.451
DRAM_ADDR12676.535
DRAM_ADDR13677.266
DRAM_ADDR14675.765
DRAM_ADDR15677.765
DRAM_BA0677.501
DRAM_BA1678.4
DRAM_BA2677.658
DRAM_CAS676.385
DRAM_CKE0677.785
DRAM_CKE1677.996
DRAM_CS0677.669
DRAM_CS1677.023
DRAM_ODT0678.446
DRAM_ODT1677.933
DRAM_RAS677.71
DRAM_RESET639.338
DRAM_WE677.802
DRAM_DQS0_N976.508
DRAM_DQS0_P974.327
DRAM_DQM0940.449
DRAM_DATA0940.361
DRAM_DATA1940.012
DRAM_DATA2940.732
DRAM_DATA3940.265
DRAM_DATA4940.431
DRAM_DATA5940.171
DRAM_DATA6940.517
DRAM_DATA7940.253
DRAM_DQS1_N775.96
DRAM_DQS1_P774.569
DRAM_DQM1775.283
DRAM_DATA8775.646
DRAM_DATA9775.115
DRAM_DATA10775.827
DRAM_DATA11775.737
DRAM_DATA12775.733
DRAM_DATA13775.446
DRAM_DATA14775.21
DRAM_DATA15775.003
