iMX6Q usdhc4 and gpmi muxing
1,551件の閲覧回数
harshakumar
Can some one tell how to mux gpmi NAND and usdhc4 pins in imx6 Quad core processor.NAND_RE uses SD4_CMD and NAND_WE uses SD4_CLK PadNets.No other mux option is given.I am using all 4 usdhc for SDIO interfaces and NAND flash for memory.If not able to mux please suggest some SDIO expander chip compatible with imx6Q processor.Please Help
3 返答(返信)
1,441件の閲覧回数
igorpadykov
Hi Harsha
for sd one can try spi option with probably some external circuitry or OneNand (weim interface)
or external controllers like, CYWB0124
http://www.mouser.com/ds/2/100/001-07978_CYWB0124AB_CYWB0125AB_WEST_BRIDGE_ANTIOC-369138.pdf
1,441件の閲覧回数
harshakumar
Hi igor
Thanks for suggestion, I am planning to use SDIO port expander TXS02612RTWR which supports two SDXC cards.
But problem is handling card detection interrupt since one card detection pin available in processor side.Can I have any suggestion
Harsha
1,441件の閲覧回数
igorpadykov
Hi Harsha
one can use GPIO for card detection, please refer to sect.32.3.3 Devicetree Binding
attached Linux Manual.
