iMX6Q OpenCL Segmentation fault
2,381件の閲覧回数
tedxi
Hello, I tried to test my OpenCL on my iMX6Q board. I have follow the steps by OpenCL Hello World .I have succeeded in compiling. And I have libGAL.so libOpenCL.so at /usr/lib. But when I run, it show me as picture 3. How this problem is caused, and how should I fix this problem.2018-02-01 17-20-25 的屏幕截图.png
ラベル(3)
2 返答(返信)
2,128件の閲覧回数
Bio_TICFSL
Hi Ted,
That's note was for ltib version where you have to copy the libOpenCL On yocto Stop copying. However it should work on Yocto, but I have not tested.
2,128件の閲覧回数
tedxi
Hi Bio,
Thanks for your suggestion.In fact I have a 120FPS camera using MJPG. I tried to use OpenCV to capture images.But OpenCV seems to be the conversion of MJPG to RGB by CPU. The frame rate of this method is only about 5FPS.
And I noticed that IPU can be used for conversion. but I find it seems convert yuv to RGB? How can I convert MJPG to RGB?
