iMX6Q HDMI audio and ESAI audio output at same time?
1,910 次查看
jasonhsu
Hi, community
Our customer has a strange requirements. ESAI audio should always output. after plug in HDMI, ESAI audio should keep outputing even if HDMI audio is working.:smileyconfused:
However, in FSL i.MX6Q Android system, ESAI will be no putput if HDMI plug in.
Could you give me some opinion about how to do such setting?:smileyhappy:
1,699 次查看
saurabh206
Senior Contributor III
Jianhua
You can modified hardware\imx\alsa\tinyalsa_hal.c according to your requirement.
Saurabh
1,699 次查看
yixuan_guo
Hi Saurabh
     Sorry!Could you give me a detailed modify?
yasin
