Hello everyone
I encounter failures when trying to use imx6 caam for HW crypto with openssl/cryptodev ("Invalid CHA selected")
(following
https://elinux.org/images/d/da/2017-02_-_ELC_-_Hudson_-_Linux_Cryptographic_Acceleration_on_an_MX6.p...)
Any idea ?
Command:
openssl speed -evp aes-128-cbc -elapsed
and the errors continuously encountered:
[ 305.394563] src @1193: a54e3f80: 096d036e 30000130 00000e7c 76f0e010 n.m.0..0|......v
[ 305.402892] ablkcipher jobdesc@1696: a8f1f0dc: b0911c08 3958f040 f1400000 38f1f15c ....@.X9..@.\..8
[ 305.412063] ablkcipher jobdesc@1696: a8f1f0ec: 00000010 f9400000 38f1f16c 00000010 ......@.l..8....
[ 305.421253] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 305.428331] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 305.436101] dst @975: a54e3f80: 096d036e 30000130 00000e7c 76f0e010 n.m.0..0|......v
[ 305.444236] cryptodev: openssl[3836] (waitfor:291): error from async request: 536874511
[ 305.452281] cryptodev: openssl[3836] (hash_n_crypt:98): CryptoAPI failure: 536874511
Tested the following ciphers:
aes-128-cbc aes-192-cbc aes-256-cbc des-cbc des-ede3-cbc
=> same result
It looks like digests test are ok
My settings:
HW: iMX6 Dual
openssl: 1.1.1g
linux kernel:
SRCBRANCH = "imx_4.14.98_2.0.0_ga"
SRCREV = "1175b59611537b0b451e0d1071b1666873a8ec32"
defconfig part (enabled debug for CAAM):
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# CONFIG_CRYPTO_USER_API is not set
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_HIFN_795X is not set
CONFIG_CRYPTO_DEV_FSL_CAAM=y
CONFIG_CRYPTO_DEV_FSL_CAAM_JR=y
CONFIG_CRYPTO_DEV_FSL_CAAM_RINGSIZE=9
# CONFIG_CRYPTO_DEV_FSL_CAAM_INTC is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_AHASH_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_PKC_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_RNG_API=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_TK_API is not set
# CONFIG_CRYPTO_DEV_FSL_CAAM_RNG_TEST is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_SM=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_SLOTSIZE=7
CONFIG_CRYPTO_DEV_FSL_CAAM_SM_TEST=y
CONFIG_CRYPTO_DEV_FSL_CAAM_SECVIO=y
CONFIG_CRYPTO_DEV_FSL_CAAM_DEBUG=y
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC=y
# CONFIG_CRYPTO_DEV_SAHARA is not set
# CONFIG_CRYPTO_DEV_MXC_SCC is not set
CONFIG_CRYPTO_DEV_MXS_DCP=y
# CONFIG_ASYMMETRIC_KEY_TYPE is not set
Some logs:
init:
2.239424] mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
[ 2.249588] mmc2: queuing unknown CIS tuple 0x1a (5 bytes)
[ 2.256241] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.258786] mmc2: queuing unknown CIS tuple 0x1b (8 bytes)
[ 2.263792] caam 2100000.caam: ERA source: CAAMVID.
[ 2.267571] mmc2: queuing unknown CIS tuple 0x14 (0 bytes)
[ 2.271784] caam 2100000.caam: AXI pipeline throttling enabled.
[ 2.283220] random: fast init done
[ 2.283938] caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
[ 2.287518] mmc2: queuing unknown CIS tuple 0x80 (1 bytes)
[ 2.293141] caam 2100000.caam: job rings = 2, qi = 0, dpaa2 = no
[ 2.298748] mmc2: queuing unknown CIS tuple 0x81 (1 bytes)
[ 2.305792] caam_jr 2101000.jr0: Entropy delay = 3200
[ 2.310189] usb 3-1: new high-speed USB device number 2 using ci_hdrc
[ 2.321915] mmc2: queuing unknown CIS tuple 0x82 (1 bytes)
[ 2.327527] mmc2: new high speed SDIO card at address 0001
[ 2.333077] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 2.376031] caam_jr 2101000.jr0: Instantiated RNG4 SH0.
[ 2.402466] mmc3: new DDR MMC card at address 0001
[ 2.407957] mmcblk3: mmc3:0001 Q2J55L 3.55 GiB
[ 2.413104] mmcblk3boot0: mmc3:0001 Q2J55L partition 1 16.0 MiB
[ 2.419715] mmcblk3boot1: mmc3:0001 Q2J55L partition 2 16.0 MiB
[ 2.426306] mmcblk3rpmb: mmc3:0001 Q2J55L partition 3 4.00 MiB
[ 2.436803] caam_jr 2101000.jr0: Instantiated RNG4 SH1.
[ 2.443962] mmcblk3: p1 p2 p3 p4 p5 p6 p7
[ 2.453686] caam algorithms registered in /proc/crypto
[ 2.460509] rng shdesc@: a8ac0008: b8800203 82500000 6834ffc0 ......P...4h
[ 2.468335] usb 3-1: device no response, device descriptor read/64, error -71
[ 2.475660] rng job desc@: a8ad0014: b0831c04 38ac0008 f800ffc0 38ac0040 .......8....@..8
[ 2.484431] usb 2-1: New USB device found, idVendor=0424, idProduct=2512
[ 2.545515] rng refreshed buf@: a8ae0000: 76d3345b 088f5b3d 48805d34 12779aef [4.v=[..4].H..w.
[ 2.545522] rng refreshed buf@: a8ae0010: 1af947ad 0f067aba 640c0529 391e30df .G...z..)..d.0.9
[ 2.545528] rng refreshed buf@: a8ae0020: 24f6600d 671f830c 4e8e9d4b c9a21139 .`.$...gK..N9...
[ 2.545535] rng refreshed buf@: a8ae0030: 79420f1c e4563b64 cabd375b a05e9b48 ..Byd;V.[7..H.^.
[ 2.557325] caam_jr 2102000.jr1: 2000030f: CCB: desc idx 3: : Invalid CHA selected.
[ 2.557380] platform caam_sm: blkkey_ex: can't cover 64-bit key
[ 2.566089] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.575071] caam-snvs 20cc000.caam-snvs: can't get snvs clock
cyrptodev loaded + openssl test:
[ 132.584352] cryptodev: loading out-of-tree module taints kernel.
[ 132.596076] cryptodev: driver 1.10 loaded.
[ 148.735855] key in @642: a9687b80: 33323130 37363534 01234567
[ 148.743337] ablkcipher enc shdesc@1116: a8f6a440: b880120b a1004004 02800008 33323130 .....@......0123
[ 148.752774] ablkcipher enc shdesc@1116: a8f6a450: 37363534 1a200008 8220010d a8080b04 4567.. ... .....
[ 148.762806] ablkcipher enc shdesc@1116: a8f6a460: a8080a04 2b120000 69300000 .......+..0i
[ 148.772213] ablkcipher dec shdesc@1190: a8f6a520: b880120b a1004004 02800008 33323130 .....@......0123
[ 148.782416] ablkcipher dec shdesc@1190: a8f6a530: 37363534 1a200008 8220010c a8080b04 4567.. ... .....
[ 148.791921] ablkcipher dec shdesc@1190: a8f6a540: a8080a04 2b120000 69300000 .......+..0i
[ 148.801488] ablkcipher givenc shdesc@1277: a8f6a600: b8801210 a1004004 02800008 33323130 .....@......0123
[ 148.811517] ablkcipher givenc shdesc@1277: a8f6a610: 37363534 10fa0004 12f30008 16860800 4567............
[ 148.822419] ablkcipher givenc shdesc@1277: a8f6a620: 79800008 16860400 5a200008 8220010d ...y...... Z.. .
[ 148.832123] ablkcipher givenc shdesc@1277: a8f6a630: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 148.841887] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 148.850012] key in @642: a9687b90: 39383736 33323130 67890123
[ 148.857473] ablkcipher enc shdesc@1116: a8f6a440: b880120f a1004008 02800018 33323130 .....@......0123
[ 148.866894] ablkcipher enc shdesc@1116: a8f6a450: 37363534 31303938 35343332 39383736 4567890123456789
[ 148.876327] ablkcipher enc shdesc@1116: a8f6a460: 33323130 1a200008 8221010d a8080b04 0123.. ...!.....
[ 148.885752] ablkcipher enc shdesc@1116: a8f6a470: a8080a04 2b120000 69300000 .......+..0i
[ 148.894871] ablkcipher dec shdesc@1190: a8f6a520: b880120f a1004008 02800018 33323130 .....@......0123
[ 148.904296] ablkcipher dec shdesc@1190: a8f6a530: 37363534 31303938 35343332 39383736 4567890123456789
[ 148.913722] ablkcipher dec shdesc@1190: a8f6a540: 33323130 1a200008 8221010c a8080b04 0123.. ...!.....
[ 148.923154] ablkcipher dec shdesc@1190: a8f6a550: a8080a04 2b120000 69300000 .......+..0i
[ 148.932275] ablkcipher givenc shdesc@1277: a8f6a600: b8801214 a1004008 02800018 33323130 .....@......0123
[ 148.941952] ablkcipher givenc shdesc@1277: a8f6a610: 37363534 31303938 35343332 39383736 4567890123456789
[ 148.951642] ablkcipher givenc shdesc@1277: a8f6a620: 33323130 10fa0004 12f30008 16860800 0123............
[ 148.961325] ablkcipher givenc shdesc@1277: a8f6a630: 79800008 16860400 5a200008 8221010d ...y...... Z..!.
[ 148.971014] ablkcipher givenc shdesc@1277: a8f6a640: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 148.988689] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 148.996861] ablkcipher enc shdesc@1116: a8f68040: b880120d a1004006 02800010 33323130 .....@......0123
[ 149.006293] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 1a200010 456789012345.. .
[ 149.015768] ablkcipher enc shdesc@1116: a8f68060: 8210010d a8080b04 a8080a04 2b120000 ...............+
[ 149.025204] ablkcipher enc shdesc@1116: a8f68070: 69300000 ..0i
[ 149.033631] ablkcipher dec shdesc@1190: a8f68120: b8801210 a1004006 02800010 33323130 .....@......0123
[ 149.043068] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 1a200010 456789012345.. .
[ 149.052497] ablkcipher dec shdesc@1190: a8f68140: a1004003 8210010c a0000002 8210110c .@..............
[ 149.061927] ablkcipher dec shdesc@1190: a8f68150: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 149.071441] ablkcipher givenc shdesc@1277: a8f68200: b8801212 a1004006 02800010 33323130 .....@......0123
[ 149.081122] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 10fa0004 456789012345....
[ 149.090811] ablkcipher givenc shdesc@1277: a8f68220: 12f30010 16860800 79800010 16860400 ...........y....
[ 149.100497] ablkcipher givenc shdesc@1277: a8f68230: 5a200010 8210010d a8080b04 a8080a04 .. Z............
[ 149.110181] ablkcipher givenc shdesc@1277: a8f68240: 2b120000 69300000 ...+..0i
[ 149.119227] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.127354] key in @642: a9687b90: 39383736 33323130 67890123
[ 149.134811] ablkcipher enc shdesc@1116: a8f68040: b880120f a1004008 02800018 33323130 .....@......0123
[ 149.144239] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.153663] ablkcipher enc shdesc@1116: a8f68060: 33323130 1a200010 8210010d a8080b04 0123.. .........
[ 149.163096] ablkcipher enc shdesc@1116: a8f68070: a8080a04 2b120000 69300000 .......+..0i
[ 149.172214] ablkcipher dec shdesc@1190: a8f68120: b8801212 a1004008 02800018 33323130 .....@......0123
[ 149.181637] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.191061] ablkcipher dec shdesc@1190: a8f68140: 33323130 1a200010 a1004003 8210010c 0123.. ..@......
[ 149.200484] ablkcipher dec shdesc@1190: a8f68150: a0000002 8210110c a8080b04 a8080a04 ................
[ 149.209908] ablkcipher dec shdesc@1190: a8f68160: 2b120000 69300000 ...+..0i
[ 149.218732] ablkcipher givenc shdesc@1277: a8f68200: b8801214 a1004008 02800018 33323130 .....@......0123
[ 149.228416] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.238101] ablkcipher givenc shdesc@1277: a8f68220: 33323130 10fa0004 12f30010 16860800 0123............
[ 149.247792] ablkcipher givenc shdesc@1277: a8f68230: 79800010 16860400 5a200010 8210010d ...y...... Z....
[ 149.257477] ablkcipher givenc shdesc@1277: a8f68240: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 149.267204] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.275330] key in @642: a9687b90: 39383736 33323130 37363534 31303938 6789012345678901
[ 149.283486] ablkcipher enc shdesc@1116: a8f68040: b8801211 a100400a 02800020 33323130 .....@.. ...0123
[ 149.292917] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.302335] ablkcipher enc shdesc@1116: a8f68060: 33323130 37363534 31303938 1a200010 012345678901.. .
[ 149.311760] ablkcipher enc shdesc@1116: a8f68070: 8210010d a8080b04 a8080a04 2b120000 ...............+
[ 149.321183] ablkcipher enc shdesc@1116: a8f68080: 69300000 ..0i
[ 149.329618] ablkcipher dec shdesc@1190: a8f68120: b8801214 a100400a 02800020 33323130 .....@.. ...0123
[ 149.339040] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.348460] ablkcipher dec shdesc@1190: a8f68140: 33323130 37363534 31303938 1a200010 012345678901.. .
[ 149.357885] ablkcipher dec shdesc@1190: a8f68150: a1004003 8210010c a0000002 8210110c .@..............
[ 149.367306] ablkcipher dec shdesc@1190: a8f68160: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 149.376777] ablkcipher givenc shdesc@1277: a8f68200: b8801216 a100400a 02800020 33323130 .....@.. ...0123
[ 149.386462] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.396145] ablkcipher givenc shdesc@1277: a8f68220: 33323130 37363534 31303938 10fa0004 012345678901....
[ 149.405828] ablkcipher givenc shdesc@1277: a8f68230: 12f30010 16860800 79800010 16860400 ...........y....
[ 149.415513] ablkcipher givenc shdesc@1277: a8f68240: 5a200010 8210010d a8080b04 a8080a04 .. Z............
[ 149.425194] ablkcipher givenc shdesc@1277: a8f68250: 2b120000 69300000 ...+..0i
[ 149.434261] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.442429] ablkcipher enc shdesc@1116: a8f68040: b880120d a1004006 02800010 33323130 .....@......0123
[ 149.451854] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 1a201010 456789012345.. .
[ 149.461283] ablkcipher enc shdesc@1116: a8f68060: 8210000d a8080b04 a8080a04 2b120000 ...............+
[ 149.470705] ablkcipher enc shdesc@1116: a8f68070: 69300000 ..0i
[ 149.479128] ablkcipher dec shdesc@1190: a8f68120: b880120d a1004006 02800010 33323130 .....@......0123
[ 149.488548] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 1a201010 456789012345.. .
[ 149.497974] ablkcipher dec shdesc@1190: a8f68140: 8210000c a8080b04 a8080a04 2b120000 ...............+
[ 149.507403] ablkcipher dec shdesc@1190: a8f68150: 69300000 ..0i
[ 149.515836] ablkcipher givenc shdesc@1277: a8f68200: b8801213 a1004006 02800010 33323130 .....@......0123
[ 149.525520] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 10fa0004 456789012345....
[ 149.535205] ablkcipher givenc shdesc@1277: a8f68220: 12f30010 16860800 79801010 16860400 ...........y....
[ 149.544890] ablkcipher givenc shdesc@1277: a8f68230: 5a201010 a1000101 8210000d a8080b04 .. Z............
[ 149.554574] ablkcipher givenc shdesc@1277: a8f68240: a8080a04 2b120000 69300000 .......+..0i
[ 149.563949] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.572080] key in @642: a9687b90: 39383736 33323130 67890123
[ 149.579538] ablkcipher enc shdesc@1116: a8f68040: b880120f a1004008 02800018 33323130 .....@......0123
[ 149.588963] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.598385] ablkcipher enc shdesc@1116: a8f68060: 33323130 1a201010 8210000d a8080b04 0123.. .........
[ 149.607806] ablkcipher enc shdesc@1116: a8f68070: a8080a04 2b120000 69300000 .......+..0i
[ 149.616913] ablkcipher dec shdesc@1190: a8f68120: b880120f a1004008 02800018 33323130 .....@......0123
[ 149.626335] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.635761] ablkcipher dec shdesc@1190: a8f68140: 33323130 1a201010 8210000c a8080b04 0123.. .........
[ 149.645222] ablkcipher dec shdesc@1190: a8f68150: a8080a04 2b120000 69300000 .......+..0i
[ 149.654339] ablkcipher givenc shdesc@1277: a8f68200: b8801215 a1004008 02800018 33323130 .....@......0123
[ 149.664026] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.673751] ablkcipher givenc shdesc@1277: a8f68220: 33323130 10fa0004 12f30010 16860800 0123............
[ 149.683444] ablkcipher givenc shdesc@1277: a8f68230: 79801010 16860400 5a201010 a1000101 ...y...... Z....
[ 149.693131] ablkcipher givenc shdesc@1277: a8f68240: 8210000d a8080b04 a8080a04 2b120000 ...............+
[ 149.702812] ablkcipher givenc shdesc@1277: a8f68250: 69300000 ..0i
[ 149.711494] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.719619] key in @642: a9687b90: 39383736 33323130 37363534 31303938 6789012345678901
[ 149.727770] ablkcipher enc shdesc@1116: a8f68040: b8801211 a100400a 02800020 33323130 .....@.. ...0123
[ 149.737221] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.746648] ablkcipher enc shdesc@1116: a8f68060: 33323130 37363534 31303938 1a201010 012345678901.. .
[ 149.756080] ablkcipher enc shdesc@1116: a8f68070: 8210000d a8080b04 a8080a04 2b120000 ...............+
[ 149.765513] ablkcipher enc shdesc@1116: a8f68080: 69300000 ..0i
[ 149.773937] ablkcipher dec shdesc@1190: a8f68120: b8801211 a100400a 02800020 33323130 .....@.. ...0123
[ 149.783374] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.792795] ablkcipher dec shdesc@1190: a8f68140: 33323130 37363534 31303938 1a201010 012345678901.. .
[ 149.803330] ablkcipher dec shdesc@1190: a8f68150: 8210000c a8080b04 a8080a04 2b120000 ...............+
[ 149.815605] ablkcipher dec shdesc@1190: a8f68160: 69300000 ..0i
[ 149.824856] ablkcipher givenc shdesc@1277: a8f68200: b8801217 a100400a 02800020 33323130 .....@.. ...0123
[ 149.834578] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 149.844297] ablkcipher givenc shdesc@1277: a8f68220: 33323130 37363534 31303938 10fa0004 012345678901....
[ 149.854045] ablkcipher givenc shdesc@1277: a8f68230: 12f30010 16860800 79801010 16860400 ...........y....
[ 149.863767] ablkcipher givenc shdesc@1277: a8f68240: 5a201010 a1000101 8210000d a8080b04 .. Z............
[ 149.873474] ablkcipher givenc shdesc@1277: a8f68250: a8080a04 2b120000 69300000 .......+..0i
[ 149.883339] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 149.891512] ablkcipher enc shdesc@1116: a8f68040: b880120d a1004006 02800010 33323130 .....@......0123
[ 149.900955] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 1a200000 456789012345.. .
[ 149.910393] ablkcipher enc shdesc@1116: a8f68060: 8210020d a8080b04 a8080a04 2b120000 ...............+
[ 149.919824] ablkcipher enc shdesc@1116: a8f68070: 69300000 ..0i
[ 149.928273] ablkcipher dec shdesc@1190: a8f68120: b8801210 a1004006 02800010 33323130 .....@......0123
[ 149.937710] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 1a200000 456789012345.. .
[ 149.947137] ablkcipher dec shdesc@1190: a8f68140: a1004003 8210020c a0000002 8210120c .@..............
[ 149.956571] ablkcipher dec shdesc@1190: a8f68150: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 149.966042] ablkcipher givenc shdesc@1277: a8f68200: b8801212 a1004006 02800010 33323130 .....@......0123
[ 149.975734] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 10fa0004 456789012345....
[ 149.985421] ablkcipher givenc shdesc@1277: a8f68220: 12f30000 16860800 79800000 16860400 ...........y....
[ 149.995105] ablkcipher givenc shdesc@1277: a8f68230: 5a200000 8210020d a8080b04 a8080a04 .. Z............
[ 150.004790] ablkcipher givenc shdesc@1277: a8f68240: 2b120000 69300000 ...+..0i
[ 150.013829] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 150.021950] key in @642: a9687b90: 39383736 33323130 67890123
[ 150.029426] ablkcipher enc shdesc@1116: a8f68040: b880120f a1004008 02800018 33323130 .....@......0123
[ 150.038851] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.048278] ablkcipher enc shdesc@1116: a8f68060: 33323130 1a200000 8210020d a8080b04 0123.. .........
[ 150.057742] ablkcipher enc shdesc@1116: a8f68070: a8080a04 2b120000 69300000 .......+..0i
[ 150.066878] ablkcipher dec shdesc@1190: a8f68120: b8801212 a1004008 02800018 33323130 .....@......0123
[ 150.076296] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.085723] ablkcipher dec shdesc@1190: a8f68140: 33323130 1a200000 a1004003 8210020c 0123.. ..@......
[ 150.095149] ablkcipher dec shdesc@1190: a8f68150: a0000002 8210120c a8080b04 a8080a04 ................
[ 150.104572] ablkcipher dec shdesc@1190: a8f68160: 2b120000 69300000 ...+..0i
[ 150.113332] ablkcipher givenc shdesc@1277: a8f68200: b8801214 a1004008 02800018 33323130 .....@......0123
[ 150.123015] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.132696] ablkcipher givenc shdesc@1277: a8f68220: 33323130 10fa0004 12f30000 16860800 0123............
[ 150.142385] ablkcipher givenc shdesc@1277: a8f68230: 79800000 16860400 5a200000 8210020d ...y...... Z....
[ 150.152069] ablkcipher givenc shdesc@1277: a8f68240: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 150.161822] key in @642: a9687b80: 33323130 37363534 31303938 35343332 0123456789012345
[ 150.169945] key in @642: a9687b90: 39383736 33323130 37363534 31303938 6789012345678901
[ 150.178114] ablkcipher enc shdesc@1116: a8f68040: b8801211 a100400a 02800020 33323130 .....@.. ...0123
[ 150.187536] ablkcipher enc shdesc@1116: a8f68050: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.196960] ablkcipher enc shdesc@1116: a8f68060: 33323130 37363534 31303938 1a200000 012345678901.. .
[ 150.206385] ablkcipher enc shdesc@1116: a8f68070: 8210020d a8080b04 a8080a04 2b120000 ...............+
[ 150.215803] ablkcipher enc shdesc@1116: a8f68080: 69300000 ..0i
[ 150.224215] ablkcipher dec shdesc@1190: a8f68120: b8801214 a100400a 02800020 33323130 .....@.. ...0123
[ 150.234041] ablkcipher dec shdesc@1190: a8f68130: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.243498] ablkcipher dec shdesc@1190: a8f68140: 33323130 37363534 31303938 1a200000 012345678901.. .
[ 150.252959] ablkcipher dec shdesc@1190: a8f68150: a1004003 8210020c a0000002 8210120c .@..............
[ 150.262395] ablkcipher dec shdesc@1190: a8f68160: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 150.271925] ablkcipher givenc shdesc@1277: a8f68200: b8801216 a100400a 02800020 33323130 .....@.. ...0123
[ 150.281650] ablkcipher givenc shdesc@1277: a8f68210: 37363534 31303938 35343332 39383736 4567890123456789
[ 150.291388] ablkcipher givenc shdesc@1277: a8f68220: 33323130 37363534 31303938 10fa0004 012345678901....
[ 150.301124] ablkcipher givenc shdesc@1277: a8f68230: 12f30000 16860800 79800000 16860400 ...........y....
[ 150.310876] ablkcipher givenc shdesc@1277: a8f68240: 5a200000 8210020d a8080b04 a8080a04 .. Z............
[ 150.320571] ablkcipher givenc shdesc@1277: a8f68250: 2b120000 69300000 ...+..0i
[ 150.337426] ahash update shdesc@372: a8ec6880: b8800206 1c200018 84400001 a8080a04 ...... ...@.....
[ 150.346684] ahash update shdesc@372: a8ec6890: 2d140000 5c200018 ...-.. \
[ 150.355226] ahash update first shdesc@383: a8ec6940: b8800205 84400005 a8080a04 2d140000 ......@........-
[ 150.364926] ahash update first shdesc@383: a8ec6950: 5c200018 .. \
[ 150.373616] ahash final shdesc@393: a8ec6a00: b8800206 1c200018 84400009 a8080a04 ...... ...@.....
[ 150.382702] ahash final shdesc@393: a8ec6a10: 2d140000 5c200010 ...-.. \
[ 150.391116] ahash digest shdesc@405: a8ec6ac0: b8800205 8440000d a8080a04 2d140000 ......@........-
[ 150.400288] ahash digest shdesc@405: a8ec6ad0: 5c200010 .. \
[ 150.408473] ahash update shdesc@372: a8ec7080: b8800206 1c200018 84400001 a8080a04 ...... ...@.....
[ 150.418493] ahash update shdesc@372: a8ec7090: 2d140000 5c200018 ...-.. \
[ 150.427609] ahash update first shdesc@383: a8ec7140: b8800205 84400005 a8080a04 2d140000 ......@........-
[ 150.440448] ahash update first shdesc@383: a8ec7150: 5c200018 .. \
[ 150.449646] ahash final shdesc@393: a8ec7200: b8800206 1c200018 84400009 a8080a04 ...... ...@.....
[ 150.459176] ahash final shdesc@393: a8ec7210: 2d140000 5c200010 ...-.. \
[ 150.470309] ahash digest shdesc@405: a8ec72c0: b8800205 8440000d a8080a04 2d140000 ......@........-
[ 150.479793] ahash digest shdesc@405: a8ec72d0: 5c200010 .. \
[ 150.488273] ahash update shdesc@372: a97d0880: b8800206 1c20001c 84410001 a8080a04 ...... ...A.....
[ 150.498422] ahash update shdesc@372: a97d0890: 2d140000 5c20001c ...-.. \
[ 150.506928] ahash update first shdesc@383: a97d0940: b8800205 84410005 a8080a04 2d140000 ......A........-
[ 150.516626] ahash update first shdesc@383: a97d0950: 5c20001c .. \
[ 150.525287] ahash final shdesc@393: a97d0a00: b8800206 1c20001c 84410009 a8080a04 ...... ...A.....
[ 150.534357] ahash final shdesc@393: a97d0a10: 2d140000 5c200014 ...-.. \
[ 150.542766] ahash digest shdesc@405: a97d0ac0: b8800205 8441000d a8080a04 2d140000 ......A........-
[ 150.551926] ahash digest shdesc@405: a97d0ad0: 5c200014 .. \
[ 150.560116] ahash update shdesc@372: a8ec7880: b8800206 1c20001c 84410001 a8080a04 ...... ...A.....
[ 150.569297] ahash update shdesc@372: a8ec7890: 2d140000 5c20001c ...-.. \
[ 150.577782] ahash update first shdesc@383: a8ec7940: b8800205 84410005 a8080a04 2d140000 ......A........-
[ 150.587463] ahash update first shdesc@383: a8ec7950: 5c20001c .. \
[ 150.596123] ahash final shdesc@393: a8ec7a00: b8800206 1c20001c 84410009 a8080a04 ...... ...A.....
[ 150.605199] ahash final shdesc@393: a8ec7a10: 2d140000 5c200014 ...-.. \
[ 150.613594] ahash digest shdesc@405: a8ec7ac0: b8800205 8441000d a8080a04 2d140000 ......A........-
[ 150.622753] ahash digest shdesc@405: a8ec7ad0: 5c200014 .. \
[ 150.630980] ahash update shdesc@372: a8ec7880: b8800206 1c200028 84420001 a8080a04 ....(. ...B.....
[ 150.640156] ahash update shdesc@372: a8ec7890: 2d140000 5c200028 ...-(. \
[ 150.648644] ahash update first shdesc@383: a8ec7940: b8800205 84420005 a8080a04 2d140000 ......B........-
[ 150.658329] ahash update first shdesc@383: a8ec7950: 5c200028 (. \
[ 150.666986] ahash final shdesc@393: a8ec7a00: b8800206 1c200028 84420009 a8080a04 ....(. ...B.....
[ 150.676061] ahash final shdesc@393: a8ec7a10: 2d140000 5c20001c ...-.. \
[ 150.684505] ahash digest shdesc@405: a8ec7ac0: b8800205 8442000d a8080a04 2d140000 ......B........-
[ 150.693679] ahash digest shdesc@405: a8ec7ad0: 5c20001c .. \
[ 150.701860] ahash update shdesc@372: a8ec6880: b8800206 1c200028 84420001 a8080a04 ....(. ...B.....
[ 150.711034] ahash update shdesc@372: a8ec6890: 2d140000 5c200028 ...-(. \
[ 150.719524] ahash update first shdesc@383: a8ec6940: b8800205 84420005 a8080a04 2d140000 ......B........-
[ 150.729207] ahash update first shdesc@383: a8ec6950: 5c200028 (. \
[ 150.737870] ahash final shdesc@393: a8ec6a00: b8800206 1c200028 84420009 a8080a04 ....(. ...B.....
[ 150.746945] ahash final shdesc@393: a8ec6a10: 2d140000 5c20001c ...-.. \
[ 150.755351] ahash digest shdesc@405: a8ec6ac0: b8800205 8442000d a8080a04 2d140000 ......B........-
[ 150.764538] ahash digest shdesc@405: a8ec6ad0: 5c20001c .. \
[ 150.772745] ahash update shdesc@372: a8ec7880: b8800206 1c200028 84430001 a8080a04 ....(. ...C.....
[ 150.781970] ahash update shdesc@372: a8ec7890: 2d140000 5c200028 ...-(. \
[ 150.790475] ahash update first shdesc@383: a8ec7940: b8800205 84430005 a8080a04 2d140000 ......C........-
[ 150.800155] ahash update first shdesc@383: a8ec7950: 5c200028 (. \
[ 150.808819] ahash final shdesc@393: a8ec7a00: b8800206 1c200028 84430009 a8080a04 ....(. ...C.....
[ 150.817894] ahash final shdesc@393: a8ec7a10: 2d140000 5c200020 ...- . \
[ 150.826291] ahash digest shdesc@405: a8ec7ac0: b8800205 8443000d a8080a04 2d140000 ......C........-
[ 150.835452] ahash digest shdesc@405: a8ec7ad0: 5c200020 . \
[ 150.843625] ahash update shdesc@372: a8ec6880: b8800206 1c200028 84430001 a8080a04 ....(. ...C.....
[ 150.852796] ahash update shdesc@372: a8ec6890: 2d140000 5c200028 ...-(. \
[ 150.861284] ahash update first shdesc@383: a8ec6940: b8800205 84430005 a8080a04 2d140000 ......C........-
[ 150.870966] ahash update first shdesc@383: a8ec6950: 5c200028 (. \
[ 150.879635] ahash final shdesc@393: a8ec6a00: b8800206 1c200028 84430009 a8080a04 ....(. ...C.....
[ 150.888709] ahash final shdesc@393: a8ec6a10: 2d140000 5c200020 ...- . \
[ 150.897144] ahash digest shdesc@405: a8ec6ac0: b8800205 8443000d a8080a04 2d140000 ......C........-
[ 150.906314] ahash digest shdesc@405: a8ec6ad0: 5c200020 . \
[ 150.932775] key in @642: a9687b80: 03020100 07060504 0b0a0908 0f0e0d0c ................
[ 150.940922] key in @642: a9687b90: 13121110 17161514 1b1a1918 1f1e1d1c ................
[ 150.949096] ablkcipher enc shdesc@1116: a8f68840: b8801211 a100400a 02800020 03020100 .....@.. .......
[ 150.958523] ablkcipher enc shdesc@1116: a8f68850: 07060504 0b0a0908 0f0e0d0c 13121110 ................
[ 150.967955] ablkcipher enc shdesc@1116: a8f68860: 17161514 1b1a1918 1f1e1d1c 1a200000 .............. .
[ 150.977384] ablkcipher enc shdesc@1116: a8f68870: 8210020d a8080b04 a8080a04 2b120000 ...............+
[ 150.986805] ablkcipher enc shdesc@1116: a8f68880: 69300000 ..0i
[ 150.995230] ablkcipher dec shdesc@1190: a8f68920: b8801214 a100400a 02800020 03020100 .....@.. .......
[ 151.004662] ablkcipher dec shdesc@1190: a8f68930: 07060504 0b0a0908 0f0e0d0c 13121110 ................
[ 151.014091] ablkcipher dec shdesc@1190: a8f68940: 17161514 1b1a1918 1f1e1d1c 1a200000 .............. .
[ 151.023557] ablkcipher dec shdesc@1190: a8f68950: a1004003 8210020c a0000002 8210120c .@..............
[ 151.032984] ablkcipher dec shdesc@1190: a8f68960: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 151.042454] ablkcipher givenc shdesc@1277: a8f68a00: b8801216 a100400a 02800020 03020100 .....@.. .......
[ 151.052136] ablkcipher givenc shdesc@1277: a8f68a10: 07060504 0b0a0908 0f0e0d0c 13121110 ................
[ 151.061829] ablkcipher givenc shdesc@1277: a8f68a20: 17161514 1b1a1918 1f1e1d1c 10fa0004 ................
[ 151.071516] ablkcipher givenc shdesc@1277: a8f68a30: 12f30000 16860800 79800000 16860400 ...........y....
[ 151.081200] ablkcipher givenc shdesc@1277: a8f68a40: 5a200000 8210020d a8080b04 a8080a04 .. Z............
[ 151.090884] ablkcipher givenc shdesc@1277: a8f68a50: 2b120000 69300000 ...+..0i
[ 151.100005] key in @642: a9687b80: 00000000 00000000 00000000 00000000 ................
[ 151.108131] key in @642: a9687b90: 00000000 00000000 00000000 00000000 ................
[ 151.116304] ablkcipher enc shdesc@1116: a8f6ac40: b8801211 a100400a 02800020 00000000 .....@.. .......
[ 151.125731] ablkcipher enc shdesc@1116: a8f6ac50: 00000000 00000000 00000000 00000000 ................
[ 151.135151] ablkcipher enc shdesc@1116: a8f6ac60: 00000000 00000000 00000000 1a200000 .............. .
[ 151.144574] ablkcipher enc shdesc@1116: a8f6ac70: 8210020d a8080b04 a8080a04 2b120000 ...............+
[ 151.154000] ablkcipher enc shdesc@1116: a8f6ac80: 69300000 ..0i
[ 151.162435] ablkcipher dec shdesc@1190: a8f6ad20: b8801214 a100400a 02800020 00000000 .....@.. .......
[ 151.171852] ablkcipher dec shdesc@1190: a8f6ad30: 00000000 00000000 00000000 00000000 ................
[ 151.181276] ablkcipher dec shdesc@1190: a8f6ad40: 00000000 00000000 00000000 1a200000 .............. .
[ 151.190708] ablkcipher dec shdesc@1190: a8f6ad50: a1004003 8210020c a0000002 8210120c .@..............
[ 151.200137] ablkcipher dec shdesc@1190: a8f6ad60: a8080b04 a8080a04 2b120000 69300000 ...........+..0i
[ 151.209602] ablkcipher givenc shdesc@1277: a8f6ae00: b8801216 a100400a 02800020 00000000 .....@.. .......
[ 151.219285] ablkcipher givenc shdesc@1277: a8f6ae10: 00000000 00000000 00000000 00000000 ................
[ 151.228971] ablkcipher givenc shdesc@1277: a8f6ae20: 00000000 00000000 00000000 10fa0004 ................
[ 151.238654] ablkcipher givenc shdesc@1277: a8f6ae30: 12f30000 16860800 79800000 16860400 ...........y....
[ 151.248340] ablkcipher givenc shdesc@1277: a8f6ae40: 5a200000 8210020d a8080b04 a8080a04 .. Z............
[ 151.258023] ablkcipher givenc shdesc@1277: a8f6ae50: 2b120000 69300000 ...+..0i
[ 151.267059] sec4_sg_ptr@: a8a2109c: 00000000 38a210bc 00000000 00000000 .......8........
[ 151.275279] sec4_sg_ptr@: a8a210ac: 00000000 3247aa2c 00000010 00000000 ....,.G2........
[ 151.283492] ablkcipher sec4_sg@1671: a8a2109c: 00000000 38a210bc 00000000 00000000 .......8........
[ 151.292654] ablkcipher sec4_sg@1671: a8a210ac: 00000000 3247aa2c 40000010 00000000 ....,.G2...@....
[ 151.301816] asked=16, nbytes16
[ 151.304899] src @1193: a247aa2c: 00000000 00000000 00000000 01000000 ................
[ 151.313164] ablkcipher jobdesc@1696: a8a2101c: b0911c08 38f6ac40 f1400000 38a2109c ....@..8..@....8
[ 151.322345] ablkcipher jobdesc@1696: a8a2102c: 00000010 f8400000 3247aa0c 00000010 ......@...G2....
[ 151.331533] caam_jr 2102000.jr1: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.338623] caam_jr 2102000.jr1: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.346377] dst @975: a247aa0c: 00000000 00000000 00000000 00000000 ................
[ 151.354509] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.362547] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.370346] sec4_sg_ptr@: a8a2115c: 00000000 38a2117c 00000000 00000000 ....|..8........
[ 151.378555] sec4_sg_ptr@: a8a2116c: 00000000 3247aa2c 00000010 00000000 ....,.G2........
[ 151.386766] ablkcipher sec4_sg@1671: a8a2115c: 00000000 38a2117c 00000000 00000000 ....|..8........
[ 151.395933] ablkcipher sec4_sg@1671: a8a2116c: 00000000 3247aa2c 40000010 00000000 ....,.G2...@....
[ 151.405090] asked=16, nbytes16
[ 151.408170] src @1193: a247aa2c: 00000000 00000000 00000000 02000000 ................
[ 151.416416] ablkcipher jobdesc@1696: a8a210dc: b0911c08 38f6ac40 f1400000 38a2115c ....@..8..@.\..8
[ 151.425574] ablkcipher jobdesc@1696: a8a210ec: 00000010 f8400000 3247aa1c 00000010 ......@...G2....
[ 151.434762] caam_jr 2102000.jr1: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.441843] caam_jr 2102000.jr1: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.449611] dst @975: a247aa1c: 00000000 00000000 00000000 00000000 ................
[ 151.457745] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.465784] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.473582] sec4_sg_ptr@: a8a2121c: 00000000 38a2123c 00000000 00000000 ....<..8........
[ 151.481793] sec4_sg_ptr@: a8a2122c: 00000000 3247aa2c 00000010 00000000 ....,.G2........
[ 151.490003] ablkcipher sec4_sg@1671: a8a2121c: 00000000 38a2123c 00000000 00000000 ....<..8........
[ 151.499162] ablkcipher sec4_sg@1671: a8a2122c: 00000000 3247aa2c 40000010 00000000 ....,.G2...@....
[ 151.508323] asked=16, nbytes16
[ 151.511405] src @1193: a247aa2c: 00000000 00000000 00000000 03000000 ................
[ 151.519673] ablkcipher jobdesc@1696: a8a2119c: b0911c08 38f6ac40 f1400000 38a2121c ....@..8..@....8
[ 151.528840] ablkcipher jobdesc@1696: a8a211ac: 00000010 f9400000 38a2122c 00000010 ......@.,..8....
[ 151.538036] caam_jr 2102000.jr1: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.545117] caam_jr 2102000.jr1: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.552884] dst @975: a247aa2c: 00000000 00000000 00000000 03000000 ................
[ 151.561020] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.569053] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.576848] sec4_sg_ptr@: a8a212dc: 00000000 38a212fc 00000000 00000000 .......8........
[ 151.585054] sec4_sg_ptr@: a8a212ec: 00000000 3247aa50 00000010 00000000 ....P.G2........
[ 151.593264] ablkcipher sec4_sg@1671: a8a212dc: 00000000 38a212fc 00000000 00000000 .......8........
[ 151.602425] ablkcipher sec4_sg@1671: a8a212ec: 00000000 3247aa50 40000010 00000000 ....P.G2...@....
[ 151.611583] asked=16, nbytes16
[ 151.614664] src @1193: a247aa50: 00000000 00000000 00000000 00000000 ................
[ 151.622891] ablkcipher jobdesc@1696: a8a2125c: b0911c08 38f68840 f1400000 38a212dc ....@..8..@....8
[ 151.632051] ablkcipher jobdesc@1696: a8a2126c: 00000010 f9400000 38a212ec 00000010 ......@....8....
[ 151.641231] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.648313] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.656082] dst @975: a247aa50: 00000000 00000000 00000000 00000000 ................
[ 151.664217] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.672252] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.680047] sec4_sg_ptr@: a8a2139c: 00000000 38a213bc 00000000 00000000 .......8........
[ 151.688255] sec4_sg_ptr@: a8a213ac: 00000000 3247aa60 00000010 00000000 ....`.G2........
[ 151.696465] ablkcipher sec4_sg@1671: a8a2139c: 00000000 38a213bc 00000000 00000000 .......8........
[ 151.705635] ablkcipher sec4_sg@1671: a8a213ac: 00000000 3247aa60 40000010 00000000 ....`.G2...@....
[ 151.714844] asked=16, nbytes16
[ 151.717932] src @1193: a247aa60: 01000000 00000000 00000000 00000000 ................
[ 151.726193] ablkcipher jobdesc@1696: a8a2131c: b0911c08 38f68840 f1400000 38a2139c ....@..8..@....8
[ 151.735418] ablkcipher jobdesc@1696: a8a2132c: 00000010 f9400000 38a213ac 00000010 ......@....8....
[ 151.744636] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.751723] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.759497] dst @975: a247aa60: 01000000 00000000 00000000 00000000 ................
[ 151.767638] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.775890] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.787641] sec4_sg_ptr@: a8a2145c: 00000000 38a2147c 00000000 00000000 ....|..8........
[ 151.796033] sec4_sg_ptr@: a8a2146c: 00000000 3247aa70 00000010 00000000 ....p.G2........
[ 151.804477] ablkcipher sec4_sg@1671: a8a2145c: 00000000 38a2147c 00000000 00000000 ....|..8........
[ 151.813688] ablkcipher sec4_sg@1671: a8a2146c: 00000000 3247aa70 40000010 00000000 ....p.G2...@....
[ 151.823090] asked=16, nbytes16
[ 151.827121] src @1193: a247aa70: 02000000 00000000 00000000 00000000 ................
[ 151.835427] ablkcipher jobdesc@1696: a8a213dc: b0911c08 38f68840 f1400000 38a2145c ....@..8..@.\..8
[ 151.844824] ablkcipher jobdesc@1696: a8a213ec: 00000010 f9400000 38a2146c 00000010 ......@.l..8....
[ 151.854045] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.861130] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.868910] dst @975: a247aa70: 02000000 00000000 00000000 00000000 ................
[ 151.877051] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.885175] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.893209] sec4_sg_ptr@: a8a2151c: 00000000 38a2153c 00000000 00000000 ....<..8........
[ 151.904014] sec4_sg_ptr@: a8a2152c: 00000000 3247aa50 00000010 00000000 ....P.G2........
[ 151.912269] ablkcipher sec4_sg@1671: a8a2151c: 00000000 38a2153c 00000000 00000000 ....<..8........
[ 151.921520] ablkcipher sec4_sg@1671: a8a2152c: 00000000 3247aa50 40000010 00000000 ....P.G2...@....
[ 151.930725] asked=16, nbytes16
[ 151.933892] src @1193: a247aa50: 54000000 30000000 f47227fc 132a13a9 ...T...0.'r...*.
[ 151.942124] ablkcipher jobdesc@1696: a8a2149c: b0911c08 38f68840 f1400000 38a2151c ....@..8..@....8
[ 151.951455] ablkcipher jobdesc@1696: a8a214ac: 00000010 f9400000 38a2152c 00000010 ......@.,..8....
[ 151.960641] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 151.967723] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 151.975496] dst @975: a247aa50: 54000000 30000000 f47227fc 132a13a9 ...T...0.'r...*.
[ 151.983639] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 151.991756] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 151.999747] sec4_sg_ptr@: a8a215dc: 00000000 38a215fc 00000000 00000000 .......8........
[ 152.010525] sec4_sg_ptr@: a8a215ec: 00000000 3247aa60 00000010 00000000 ....`.G2........
[ 152.018780] ablkcipher sec4_sg@1671: a8a215dc: 00000000 38a215fc 00000000 00000000 .......8........
[ 152.028022] ablkcipher sec4_sg@1671: a8a215ec: 00000000 3247aa60 40000010 00000000 ....`.G2...@....
[ 152.037189] asked=16, nbytes16
[ 152.040376] src @1193: a247aa60: 55000000 30000000 f47227fc 132a13a9 ...U...0.'r...*.
[ 152.048607] ablkcipher jobdesc@1696: a8a2155c: b0911c08 38f68840 f1400000 38a215dc ....@..8..@....8
[ 152.057783] ablkcipher jobdesc@1696: a8a2156c: 00000010 f9400000 38a215ec 00000010 ......@....8....
[ 152.066959] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 152.074047] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 152.081816] dst @975: a247aa60: 55000000 30000000 f47227fc 132a13a9 ...U...0.'r...*.
[ 152.089952] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 152.097984] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 152.105786] sec4_sg_ptr@: a8a2169c: 00000000 38a216bc 00000000 00000000 .......8........
[ 152.113991] sec4_sg_ptr@: a8a216ac: 00000000 3247aa70 00000010 00000000 ....p.G2........
[ 152.122210] ablkcipher sec4_sg@1671: a8a2169c: 00000000 38a216bc 00000000 00000000 .......8........
[ 152.131381] ablkcipher sec4_sg@1671: a8a216ac: 00000000 3247aa70 40000010 00000000 ....p.G2...@....
[ 152.140574] asked=16, nbytes16
[ 152.143662] src @1193: a247aa70: 56000000 30000000 f47227fc 132a13a9 ...V...0.'r...*.
[ 152.151905] ablkcipher jobdesc@1696: a8a2161c: b0911c08 38f68840 f1400000 38a2169c ....@..8..@....8
[ 152.161063] ablkcipher jobdesc@1696: a8a2162c: 00000010 f9400000 38a216ac 00000010 ......@....8....
[ 152.170248] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 152.177329] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 152.185098] dst @975: a247aa70: 56000000 30000000 f47227fc 132a13a9 ...V...0.'r...*.
[ 152.193233] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 152.201265] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 152.209063] sec4_sg_ptr@: a8a2175c: 00000000 38a2177c 00000000 00000000 ....|..8........
[ 152.217271] sec4_sg_ptr@: a8a2176c: 00000000 3247aa50 00000010 00000000 ....P.G2........
[ 152.225496] ablkcipher sec4_sg@1671: a8a2175c: 00000000 38a2177c 00000000 00000000 ....|..8........
[ 152.234661] ablkcipher sec4_sg@1671: a8a2176c: 00000000 3247aa50 40000010 00000000 ....P.G2...@....
[ 152.243817] asked=16, nbytes16
[ 152.246898] src @1193: a247aa50: cb62f438 e21f93b2 5caa49e0 8fabde4a 8.b......I.\J...
[ 152.255127] ablkcipher jobdesc@1696: a8a216dc: b0911c08 38f68840 f1400000 38a2175c ....@..8..@.\..8
[ 152.264286] ablkcipher jobdesc@1696: a8a216ec: 00000010 f9400000 38a2176c 00000010 ......@.l..8....
[ 152.273463] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 152.280545] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 152.288313] dst @975: a247aa50: cb62f438 e21f93b2 5caa49e0 8fabde4a 8.b......I.\J...
[ 152.296447] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 152.304485] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 152.312285] sec4_sg_ptr@: a8a2181c: 00000000 38a2183c 00000000 00000000 ....<..8........
[ 152.320502] sec4_sg_ptr@: a8a2182c: 00000000 3247aa60 00000010 00000000 ....`.G2........
[ 152.328720] ablkcipher sec4_sg@1671: a8a2181c: 00000000 38a2183c 00000000 00000000 ....<..8........
[ 152.337884] ablkcipher sec4_sg@1671: a8a2182c: 00000000 3247aa60 40000010 00000000 ....`.G2...@....
[ 152.347077] asked=16, nbytes16
[ 152.350163] src @1193: a247aa60: ca62f438 e21f93b2 5caa49e0 8fabde4a 8.b......I.\J...
[ 152.358402] ablkcipher jobdesc@1696: a8a2179c: b0911c08 38f68840 f1400000 38a2181c ....@..8..@....8
[ 152.367568] ablkcipher jobdesc@1696: a8a217ac: 00000010 f9400000 38a2182c 00000010 ......@.,..8....
[ 152.376748] caam_jr 2101000.jr0: ablkcipher_encrypt_done 962: err 0x20000e0f
[ 152.383830] caam_jr 2101000.jr0: 20000e0f: CCB: desc idx 14: : Invalid CHA selected.
[ 152.391602] dst @975: a247aa60: ca62f438 e21f93b2 5caa49e0 8fabde4a 8.b......I.\J...
[ 152.399736] cryptodev: openssl[3535] (waitfor:291): error from async request: 536874511
[ 152.407770] cryptodev: openssl[3535] (hash_n_crypt:98): CryptoAPI failure: 536874511
[ 152.415565] sec4_sg_ptr@: a8a218dc: 00000000 38a218fc 00000000 00000000 .......8........
[ 152.423771] sec4_sg_ptr@: a8a218ec: 00000000 3247aa70 00000010 00000000 ....p.G2........
[ 152.431987] ablkcipher sec4_sg@1671: a8a218dc: 00000000 38a218fc 00000000 00000000 .......8........
[ 152.441149] ablkcipher sec4_sg@1671: a8a218ec: 00000000 3247aa70 40000010 00000000 ....p.G2...@....
[ 152.450307] asked=16, nbytes16
One can refer to "i.MX Encrypted Storage Using CAAM Secure Keys" Application Note:
https://www.nxp.com/docs/en/application-note/AN12714.pdf
Sorry but I don't see the link with my issue.
As far I know, your AN is about DM crypt , not using openssl for basic aes-128-cbc for example.
I tested on a wandboard with a 5.4.86 mainline kernel and it works.
for both linux 4.14 and 5.4 imx branches, if I disable some CAAM features in dtsi (see below), errors disapear BUT performances are ugly... => it looks like a bad pure SW encryption (CPU load=100% and bandwidth worst than pure SW)
imx6qdl.dtsi
caam_sm: caam-sm@100000 {
compatible = "fsl,imx6q-caam-sm";
reg = <0x100000 0x4000>;
irq_sec_vio: caam_secvio {
compatible = "fsl,imx6q-caam-secvio";
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
jtag-tamper = "disabled";
watchdog-tamper = "enabled";
internal-boot-tamper = "enabled";
external-pin-tamper = "disabled";
caam_snvs: caam-snvs@20cc000 {
compatible = "fsl,imx6q-caam-snvs";
reg = <0x20cc000 0x4000>;
We have no exact numbers for CAAM performance. Sorry for the inconvenience.
However one can refer to i.MX6 CAAM performance benchmark test code:
https://community.nxp.com/t5/iMX-and-Vybrid-Support/i-MX6S-CAAM-performance-benchmark-test-code/m-p/...
