Wigros,
Please find attached the logs of my system.
Look forward to hear from you.
<http://www.techmahindra.com/>
Rohit Kp
Sr. Software Engineer | Automotive Infotainment
Electronic City | Bengaluru | India
Office: (+91) 80 67807777 Extn: 851478
Email ID<mailto:RP00352447@techmahindra.com>: RP00352447@TechMahindra.com
techmahindra.com<http://www.techmahindra.com/>
We believe
<http://www.facebook.com/techmahindra>[Description: Description: Description: cid:image004.png@01D0A510.436B2720]<http://www.twitter.com/tech_mahindra>[Description: Description: Description: cid:image011.png@01D0A51D.F8D493A0]<https://www.linkedin.com/company/tech-mahindra>[Description: Description: Description: cid:image006.png@01D0A510.436B2720]<https://www.youtube.com/user/TechMahindra09>
<http://online.wsj.com/ad/inthefuture/>
Disclaimer: This message and the information contained herein is proprietary and confidential and subject to the Tech Mahindra policy statement, you may review the policy at http://www.techmahindra.com/Disclaimer.html externally http://tim.techmahindra.com/tim/disclaimer.html internally within TechMahindra.
Original Attachment has been moved to: BT-Scan.txt.zip
Original Attachment has been moved to: BT-Enable-first-time.txt.zip
Original Attachment has been moved to: BT-Pair.txt.zip
Hi Rohit,
I checked your log, it seemed that your Bluetooth has been working. Actually, you only need to refer to source code for BCM4339 of SabreSDP, and port BT's configuration to your board, so you will have to take some time to read corresponding source code for sabreSDP.
Weidong
Hi Wigros,
I hope all the profiles from my stack is working fine.
But i want to test the HFP(handsfree profile), Can you provide me some app which you may have used for testing?
I am not from Application development, So struggling a lot to realize the calling functionality over BT.
Any help on this from you will be great help to me.
Thank you,
Rohit
