I am working in iMX6DL. I wants to enable LCD display for 480 x 272. By default, it supports LVDS. I have modified in imx6sabresd.c file. Now am getting display in LCD. But resolution is larger and it still supports 800 x 480 only. Is their any place Resolution is hard coded which I needs to modify?
Probably this thread can help you.
What is the interface for this LCD, using the LVDS port?
What have you modied? Can you share where you have modified, I will check for you. Have you using the create clock? Which version of BSP are you using?
