I am working with a NXP/Freescale SabreSD board (27417 - iMX6DL variant) and need to get access to some pins for testing. These pins are available on J504 which is a 120 pin Mictor style connector that is used for a LCD Expansion port. I can't solder to this connector as the pins are way too fine. My best bet is to get a breakout for it.
Does anyone know of the actual manufacturer's part # for the connector mate? Does anyone know of a breakout board that can connect up to this connector?
Doug Bailey
Solved! Go to Solution.
Hi Doug
J504 connector part is SAMTEC QSH-060-01-L-D-A
Thanks for the info.
Hi Doug
