we are designing a board with i.MX6 Quad and DDR3 and we are in doubt about how to calculate clock length.
As you can see in the image below, we have tracks that go from CPU to RAM chips, and than they go on to the termination resistor (highlighted with the arrows).
Are those tracks to be counted in the clock length? Or should we only count the path from CPU pad to RAM pad?
Thank you very much
Have a nice day
Ilario Gottardello
Solved! Go to Solution.
Hi Ilario
right, one should count the path from CPU pad to RAM pad.
Hi Ilario
