iMX6:MYS-6ULX-IoT-EVK: Booting custom Linux from sdcard
Search instead for
KalyanAgepati
Hi NXP Technical Support Team,
I am working on how to boot the custom Linux(rootfs) from sd-card on MYS-6ULX-IoT-EVK(iMX6 board). Can you please let me know the instructions to copy the UBoot, Kernel (zImage) and Device Tree Blob (dtb) images into an sd-card?
Also please let me know, how to instruct the existing nand u-boot loader to boot Linux system from sd-card?
For your information, I am using VM Ubuntu-16.04.5-desktop-amd64. I have downloaded Yocto toolchain sdk, fsl-release-yocto, Yocto-downloads, MYiR-iMX-Linux and MYiR-iMX-Uboot source code downloaded from the website http://down.myir-tech.com/MYS-6ULX/
For your information, my build “bitbake core-image-base” went well and images got generated at tmp/deploy/images/imx6qsabresd and attached screenshot of the images.
Kalyan
Bio_TICFSL
Hello KalyanAgepati,
You might see the Yocto user guide that includes how to burn your sdcard to start using the MX6ULEVK,
https://www.nxp.com/docs/en/user-guide/IMXLXYOCTOUG.pdf
For your board you need check with your vendor.
regards
