iMX6 HDMI disable issue
yurykazakevich
Hi everyone.
According to the answer on that question How to disable HDMI when board is booted I tried to disable HDMI on my custom board based on the iMX6 cpu.
I added in the bootargs the following options: 'video=mxcfb0:off video=mxcfb1:off video=mxcfb2:off ' and as a result kernel hangs without any errors, oops and etc.
I get the same behavior when I disable frame buffer support in the kernel.
My kernel version is 3.14.28
What can be a reason of that?
Labels (3)
jimmychan
you may try to set the HDMI to fb0, then run this "$echo 1 /sys/class/graphics/fb0/blank" after linux is up.
yurykazakevich
Thank you, Jimmy.
That command helps but sometimes kernel still freezes. Maybe you know how to find a reason of that or how to find out?
