iMX53 composite video signal out not working
Showing results forย
Search instead forย
Did you mean:ย
AllenMekerdichi
We are not successful in getting out Composite video
signal.
We are using following uBoot config line:
setenv tv 'setenv bootargs console=ttymxc0,115200
video=mxcdi1fb:YUV444,TV-PAL di1_primary tve'
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200
gpu_nommu ${tv}'
can some please advise how we can enable Composite video output on i.mx53
weidong_sun
Hello,Allen,
      Try to set the following parameters in u-boot ( For Linux System )
u-boot >setenv bootargs_base โ€˜setenv bootargs console=ttymxc0,115200โ€™
u-boot >setenv bootargs_mmc โ€˜setenv bootargs ${bootargs} root=/dev/mmcblk0p1 rootfstype=ext4 rw video=mxcdi1fb:YUV444,TV-PAL di1_primary tveโ€™
u-boot >setenv bootcmd_mmc โ€˜run bootargs_base bootargs_mmc;mmc dev 1 ; mmc read ${loadaddr} 0x800 0x1800;bootmโ€™
u-boot >setenv bootcmd โ€˜run bootcmd_mmcโ€™
Weidong
weidong_sun
Hello,Allen,
Weidong
AllenMekerdichi
Hi Weidong
"The settings given are what my customer has already used. They don't work"
They would like to know how to turn on the composite?
Allen Mekerdichian
Field Applications Engineer
Avnet Electronics Marketing
Tel: (02) 9585 5515
Mobile: 0438 640 686
Fax: (02) 9585 5519
Email: Allen.Mekerdichian@avnet.com<mailto:Allen.Mekerdichian@avnet.com>
www.avnet.com<http://www.avnet.com>;
Accelerating Your Successโ„ข
weidong_sun
Hello,Allen,
      Could you tell me your CPU version and BSP version?
Regards.
Weidong
