iMX53 choose boot from which mmc interface?
1,178 次查看
JayZhang
Is there a GPIO pin that can choose which mmc interface to boot up ?
Sorry for my poor English and thanks for your suggest!
6 回复数
913 次查看
JayZhang
Hy,
Thanks a lot.
xizhou wang said:
FYI
Comment by Mark Middletonon November 28, 2011 at 10:40am
To boot from SD3 (Full size SD Card socket), the "short" answer is to solder a wire between pads 2 & 19 of SW1. See picture. For more detail, see section 5.4.2 of the HW User Guide. The SW1 footprint was designed for a Multicomp MCNHDS-10-T Dip switch.
913 次查看
xizhouwang
FYI
913 次查看
Yuri
SD port select option BOOT_CFG3[5:4] (EIM_DA6, EIM_DA7) may be configured on (BOOT) SW1
of the QSB. Please use the scheme for details.
Also one may look at section 5.5.2 (Boot Mode Operations and Selections)
of “Hardware Reference Manual for i.MX53 Quick Start”.
913 次查看
KrishnaPavan
Hi Yuri Mihin,
What about the DIP Switches, that are used in general then?
What should be the state of them, If we use GPIO Pins directly?
913 次查看
Yuri
According to Table 7-15 (ESDHC Boot eFUSE Descriptions) of i.MX53 Reference
Manual (RM), BOOT_CFG3[5:4] fuses are responsible for SD port selection.
Table 7-3 (GPIO Override Contact Assignments) of the RM shows what pins
may be used instead of fuses.
http://cache.freescale.com/files/32bit/doc/ref_manual/iMX53RM.pdf
913 次查看
JayZhang
Any one can help me?
