iMX53 Tablet Camera image is mirrored
910 次查看
CJLim
Anyone notice that the pictures/video captured by the camera is mirrored image. How and where can I set it to become normal?
标记 (1)
4 回复数
777 次查看
Yanfei_Sun
this must be related to the IPU settings to catch the image. check the related IDMAC channel settings, bit field hf. and then check if the horizental flip is enabled in your IC Tasks.(register IC_IDMAC_1).
777 次查看
daiane_angolini
You should take a look on CameraHal as well
android/hardware/mx5x/libcamera/CameraHal.cpp
What release are you using?
777 次查看
CJLim
I'm using android.
it's very easy to see that it's a mirror image by taking a picture of some words. Usually the front facing camera would show a mirror image but after you take the picture, the save image is flipped back to the normal view.
777 次查看
daiane_angolini
I haven´t. I always get confused about what is a mirrored, 90', 180' rotated image...
And my tablet don´t have any orientation, só I had never thought about it.
Are you using linux or Android?
I know capture driver can handle some camera configuration (and obviously camera driver as well).
Open the file
kernel/drivers/media/video/mxc/capture/mxc_v4l2_capture.c
and search for rotate or for function mxc_v4l2_s_param
