Hi Masatoshi,
As Sinan say above, you can purchase directly from Freescale or trough one of its distributors. Here is the link https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX53QSB&tab=Buy_Parametric_Tab&from.... By the way, you can choose the board MCIMX53-START-R, it's new and there is power management IC MC34708 on it. Any questions contact us , we are pleasure to help you~~
Dan
Hello Dan,
Thank you for your information.
I mentioned to the board for replying Sinan's mail. I already use the MCIMX53-START-R, already.
I am looking for which exactly i.MX53 EVK board. Or, if the other board to be able to boot Linux from on-board NAND flash. These are the requirements I need.
If you have those information such to be discontinued i.MX53 EVK board already, the distributor of the other board, etc. , please tell me.
Watanabe
Hi Masatoshi,
The i.MX53_SABRE_TABLET(SMD board) supports emmc.The link is http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=RDIMX53SABRETAB. The i.MX53 EVK board is not exist now. It was the first board for i.MX53 at the beginning. But the performance is not good. So FSL not make it again. Now, we only have QSB and SMD boards for customer to order.And you also can consider i.MX6.
Dan
Dear Dan,
Thank you!
I understood the EVK board is discontinued.
I also consider i.MX6, too.
Thank you very much.
Watanabe
Hi Masatoshi,
My pleasure :smileyhappy:. If any questions, we are here pleasure to help you.
Dan
Hi Masatoshi
Here is the info for imx53 board : http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX53QSB
You can purchase directly from Freescale or trough one of its distributors.
Hope this helps.
Sinan Akman
Dear Sinan,
Thank you for your reply.
Yes, I have used to use the product already.
I meant i.MX53 EVK is what exactly named i.MX53 EVK board not i.MX53 QSB.
I found the board at the document 'i.MX53_EVK_Linux_BSP_UserGuide.pdf' in 'L2.6.35_11.09.01_ER_docs' directory. The download URL is: https://www.freescale.com/webapp/Download?colCode=L2.6.35_MX53_ER_1109_IMAGE_&prodCode=IMX53QSB&appT...
And, according to the introduction of the document, it said the document is for the board 'i.MX53 EVK Board'. It doesn't say iMX53QSB.
I am looking for a iMX53 evaluation board which bootable from on-board NAND flash. I found one which is ROM1210. But, it is difficult to buy from Japan.
If you have another option for this. Please tell me the distributor.
Watanabe
