iMX287 LRADC giving intermittent 4095 (max) value
Search instead for
sam_jaeschke
I'm using Linux 4.8.17 from this commit: GitHub - Freescale/linux-fslc at 35ef7950aaf7caa28afae35160bda0734ecfeba7
My device tree has this:
#include "imx28.dtsi"
&lradc {
   status = "okay";
   fsl,lradc-touchscreen-wires = <4>;
   fsl,ave-ctrl = <4>;
   fsl,ave-delay = <2>;
   fsl,settling = <10>;
When I read from LRADC channels 2 and 3, I get the value 4095 (maximum for 12-bits) at regular intervals. The timing does not even need to be regular to behave this way.
# cat /sys/devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/iio\:device0/in_voltage2_raw
4095
2393
2413
2395
4095
2393
2411
2393
4095
2395
2413
2395
4095
# cat /sys/devices/soc0/80000000.apb/80040000.apbx/80050000.lradc/iio\:device0/in_voltage3_raw
4095
2413
4095
2413
4095
2411
4095
2413
4095
2413
There is no way the actual voltage is fluctuating at just the same time as the voltage gets read at irregular intervals.
Is this a problem that has been seen before? What could be going wrong?
Interestingly, channels 4-5 follow a pattern of going low (13-16) at regular intervals: Voltage, Voltage, 14, 16, Voltage, Voltage, 15, 13, Voltage, Voltage. That also seems odd.
Every other channel behaves fine.
Many thanks.
Labels (2)
sam_jaeschke
That was a bit silly....
I'm not using a touch screen, so I removed "fsl,lradc-touchscreen-wires = <4>;" from the device tree and it worked!
sam_jaeschke
