iMX286 USB OTG assigned to what contact pins?
Search instead for
rakshith_manjun
Hey, I was wondering what pin contacts is assigned to the USB OTG controller and what contacts for the Host only controller. I tried skimming through the datasheet and reference manual, I don't seem to find it.
USB0DM -> A10
USB0DP -> B10
USB1DM -> B8
USB1DP -> A8
Could any one in the community be kind enough to help me on this. Your time and effort is much appreciated. Thank you.
Rakshith
Tags (2)
Hi Rakshith
pinout can be found in Table 65. i.MX287 MAPBGA Contact Assignments i.MX28 Datasheet
https://www.nxp.com/docs/en/data-sheet/IMX28CEC.pdf
for connections may be helpful to check i.MX28EVK schematic
i.MX28 Evaluation Kit | NXP
