i2c node in the dts file
ソリューションへジャンプ
2,212件の閲覧回数
Embedded-world
Dear Experts,
I'm working imx6ull dts files so here,
&i2c1 {
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2c1>;
status = "okay";
pcf8563@51 {
status = "okay";
compatible = "nxp,pcf8563";
reg = <0x51>;
In the above dts i2c structure i didn't understand the @51 and reg = <0x51> values, How to assign these value from the datasheet ? someone could give me clarity about this.
Thanks and Regards,
Ravikumar
2,194件の閲覧回数
Zhiming_Liu
Hi @Embedded-world
The 0x51 is  your i2c slave device address. You should check datasheet or user guide.
Best Regards
Zhiming
2,195件の閲覧回数
Zhiming_Liu
Hi @Embedded-world
Best Regards
Zhiming
