i want to know how flash image into emmc
639 次查看
srinivas_123
i am using imx8mplus custom board . i build the IMXLXYOCTOUG v.LF6.6.3_1.0.0  BSP .
i want to flash image into emmc .please help me out.
how to flash uboot , kernel and rootfs separetly into emmc.
how to flash wic image into emmc.
please help me .
Thank&Regards
srinivas
618 次查看
chillinwithscb
I have only worked with eval kits so far. I use UUU to write images to eMMC. For that to work for you I guess you need a USB download port on your board and your U-Boot image needs to support UUU. There is info in the UUU wiki about that. That's the best I can do for you. You have your work cut out for ya. Best of luck!
The tool is at https://github.com/nxp-imx/mfgtools
Latest executable: https://github.com/nxp-imx/mfgtools/releases/tag/uuu_1.5.182
Wiki: https://github.com/nxp-imx/mfgtools/wiki
