hi nxp,
our platform is imx8qxp, software is L4.14.98_2.0.0. i want to know some software errata have been fix or not at SDK L4.14.98_2.0.0.
1) here is the errata document:Mask Set Errata for Mask 0N95W ;
2) task "e50068: AUDIO: Incorrect 24 MHz clock source at Audio Clock Mux input" for example, how do I know wether it have been fix at SDK L4.14.98_2.0.0 or not?
Errata ID | Errata Subject | Software Fix Version | I.MX8QXP | I.MX8DXP | Commit URL |
e50061 | ANALOG: DPLL loses lock under corner conditions | L4.14.98_2.0.0? | B0 Fix ? | NO | |
e50055 | N/A | C0 Fix ? | YES |
BR,
Solved! Go to Solution.
Hi jianwei,
The errata appears to be unfixed in bsp 4.15.98 but it appears to be fixed in 4.19.35
Hello jianwei,
Sorry that errata has not been fixed yet.
Hello Bio_TICFSL,
Thank for your kindly help.
1) Does you mean that all the errata at Mask Set Errata for Mask 0N95W have not been fix at SDK L4.14.98_2.0.0 ?
2) How do you know that errata has not been fixed yet, can you help to provide more information ?
BR.
Hi jianwei,
Hello Bio_TICFSL,
>The errata appears to be unfixed in bsp 4.15.98 but it appears to be fixed in 4.19.35.
How can I know wether the each errata at Mask Set Errata for Mask 0N95W have been fixed or not ?
BR.
