i.mx8m plus support lpddr4 and lpddr4x
6,449 次查看
zc_tee
Dear all,
May i know does i.mx8M Plus support both LPDDR4 and LPDDR4x RAM?
Thank you.
Tee
6,440 次查看
Yuri
@zc_tee
   I've sent You some comments directly.
Yuri.
11 回复数
6,158 次查看
040869
Could I also get your comment? Interesting usage LPDDR4X >32Gb on own project.
Thanks!
6,339 次查看
richard_hu
Senior Contributor I
@Yuri
We are considering to use LPDDR4X as well.
6,328 次查看
Yuri
@richard_hu
  Done!
6,441 次查看
Yuri
@zc_tee
Yuri.
4,885 次查看
amigen-jason
Yuri,
I'd like the comments as well.  We would like to use an LPDDR4X with the i.MX 8MPlus purely for power savings (not increased bandwidth), if possible.
We currently run LPDDR4 at 800 MHz as our systems do not have intensive memory bandwidth requirements, but do have extreme low power requirements (on battery).
5,537 次查看
aviad_h
@Yuri
Can you please share comments
6,066 次查看
torus1000
@Yuri
Could I also get your comment? Thanks!
6,062 次查看
Yuri
@torus1000
   The 8M Plus does not support LPDDR4x.
Yuri.
6,282 次查看
anhui527
Could I also get your comment? thanks.
6,275 次查看
Yuri
@anhui527
  I've sent You comments in Case Number 00328551.
Yuri.
6,436 次查看
zc_tee
Thank you! got your comment already.
Tee
